HELP - Removing Aero Wiper blades on B7
Stepho Jun 27, 2012
  1. Stepho
    Stepho Member
    444
    Need someone to tell me how to remove the old Aero Wiper blades on a B7 A4. Really struggling with this one. On it at the moment.
    Thanks in advance
  2. Stepho
    Stepho Member
    444
    Anyone?????????????
  3. Custardsucker
    Custardsucker Member
    112
    On the end of the arm where the blade is attached you will see a joint line. Grab the end piece and pull, the joint should open and this will allow the blade to come off
  4. alpesh26
    alpesh26 Active Member TeamMisano
    424
    45
    They can be quite tight but make sure you pull it off straight so you don't damage anything
  5. Stepho
    Stepho Member
    444
    Cheers guys, your absolute stars. Job done. Think it was the origional set that was on as they were tighter than a ducks a*$e
  6. ANDYTQ
    ANDYTQ Well-Known Member
    1,186
    106
    I had the same problem,the air was blue,figured it out in the end ,just fooking tight,lol
  7. RYN-LDN
    RYN-LDN Member
    35
    Ditto! Was a cold day when I was removing the wipers.. Couldn't feel my hands when I finished!
