HELP REMOVE REAR BUMPER
a4 2.4 se Jul 23, 2007
  1. Hi all i need some help to remove my rear bumper of my a4 avant 2002 to fit and tow bar can any one help or does any one now who can fit one in leicester area
    thanks
    paz
  2. ianpic
    ianpic New Member
    I fitted a towbar to mine a few weeks ago. There are a couple of screws in each wheel arch, 2 under the lower lip and then you have to get access below the light clusters through the trim inside the boot. Below the lights there are 3 nuts each side that need to be removed. These are quite low down, I managed to just move the trim away enough to get my arm in to undo the nuts. Mine has also got the sub-woofer/bass unit on the rh side which had to come out. A bit tight that one.........
  3. terrysingh
    terrysingh Member
    184
    a4mods.com
  4. just had it booket in to have witter detachable towbar fitted £267
  5. ianpic
    ianpic New Member
    Thats not bad. I paid £135 for a bosal detatchable kit but then fitted it myself. The actual towbar wasn't too bad too fit but the electrics were more tricky as you have to fit a relay not stop nuisance bulb warnings.
  6. do you have any pic of your tow bar just had my fittef it cost me £330 and wat an fuxk up
