HELP!!!!!!!!! possesed A8
naushad Mar 31, 2008
  1. naushad
    naushad New Member
    Help, I have an A8L BFM engine code, that wont start, the ignition switch seems to have gone on strike!! when i insert the key in the switch the steering lock usually releases but now there's nothing, when i try and use the start button it works some times and some times it says 'key not identifeid' when im holding the key inside the car!!!! has any body had this experience before??? Also this problem started with the battery being changed, PLEASE HELP:wtf:
  2. audi5e
    audi5e Member
    809
    You probably need to take the car to Audi to have the key reprogrammed. Sounds like something is out of sync after the battery change?
