Help please ??
dplovin Oct 24, 2012
  1. dplovin
    dplovin Member
    416
    Just had my 1.8t in the garage to replace the lower temp sensor. Should of done it myself.
    Well he's cleaned the throttle body aswell without him telling me but now just drove it back and the engine management light has come on and it feels like its missfiring.
    does as miss fire on a b6 throw the management light on?? Hopefully it's just that.
    never going there again.
    ill have to wait untill I'm home to use vagcom now
  2. dplovin
    dplovin Member
    416
    Well I'm presuming its a miss fire anywZy feels like one
  3. hades-
    9,482
    646
    the light will flash for missfires
    take it back to him
  4. dplovin
    dplovin Member
    416
    Luckily I only paid £30 to fit the sensor dnt want to trust them with it again just going to replace the coil packs myself. Anybody know how to log which ones missfiring with vcds ??
  5. hades-
    9,482
    646
    what code are you geting ?
  6. dplovin
    dplovin Member
    416
    Gonna scan it now mate 2 ticks
  7. dplovin
    dplovin Member
    416
    [FONT=Arial,sans-serif][SIZE=-1][FONT=Arial,sans-serif][SIZE=-1][FONT=Arial,sans-serif][SIZE=-1]3 Faults Found:
    [/SIZE][/FONT] [FONT=Arial,sans-serif][SIZE=-1]16684 - Random/Multiple Cylinder Misfire Detected
    [/SIZE][/FONT][FONT=Arial,sans-serif][SIZE=-1] P0300 - 35-00 -
    [/SIZE][/FONT][FONT=Arial,sans-serif][SIZE=-1]16688 - Cylinder 4
    [/SIZE][/FONT][FONT=Arial,sans-serif][SIZE=-1] P0304 - 35-00 - Misfire Detected
    [/SIZE][/FONT] [FONT=Arial,sans-serif][SIZE=-1]17658 - Fuel Level too Low
    [/SIZE][/FONT][FONT=Arial,sans-serif][SIZE=-1] P1250 - 35-00 -
    [/SIZE][/FONT][FONT=Arial,sans-serif][SIZE=-1]Readiness: 0010 1101[/SIZE][/FONT]
    [/SIZE][/FONT]
    [/SIZE][/FONT]
  8. dplovin
    dplovin Member
    416
    Cylinder four ? Which ones that guys
  9. hades-
    9,482
    646
    change 4 to 1 gor for a drive then rescan
    see if the miss has moved to number 1
    just swap the first 1 and last 1 round
  10. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    and just for your info 1 is always the cam belt side
    so 4 is the back one
    dplovin likes this.
  11. hades-
    9,482
    646
    i think so but not 100% sure
    but it wont matter as when you swap them if the miss follows you know its the coil pack
    and they do go quite offen
    i always carry a spare in the boot for that reason
    dplovin likes this.
  12. dplovin
    dplovin Member
    416
    update guys went crewe audi thismorning for a new coil pack £38 they charged, just fitted it and hey presto all good now!! cheers for the help :)
  13. pauldazzle
    pauldazzle Well-Known Member
    1,193
    95
    There's a recall on some VAG coilpacks. Check with your Audi dealer to see if you car is covered as they will replace all 4 coilpacks FOC if it is.
  14. dplovin
    dplovin Member
    416
    Yeah your right mate but I think it was for those with the bolt down ones mine are push downs
  15. pauldazzle
    1,193
    95
    Yes the push down coilpacks aren't covered on the VAG recall. Though they do seem to fail too.
  16. boomtown
    boomtown Member
    130
    all my push down coilpacks were replaced under recall !
  17. pauldazzle
    1,193
    95
    dplovin you better get down to Audi then.
  18. dplovin
    dplovin Member
    416
    Wow I got fobbed off last time I rang, I certainly will call again f**kers
