Help please with vag-com code
billybravo Jul 8, 2006
  1. billybravo
    billybravo Active Member
    1,045
    hello on my way home today my car just went funny like it was missing i got it home just and the vag-com came up with this code
    01252 / fuel injector (n33) 28-00 short to b+
    can anyone help please
  2. billybravo
    1,045
    ok ive got some more info
    Output on V.A.G 1551 printer
    Possible cause of fault
    Possible effects
    Fault rectification
    01252
    Injector, cylinder 4 -N33
    Short to positive
    - Short to positive
    - Injector defective
    does this help anyone
  3. madkebab
    madkebab Member
    418
    mate check the wiring to injector on cylinder no4 also check check fuse for injector circuit. If these look ok swop injector on 4 with another one reset VAG-COM and see if the fault moves. Then you will know that the injector has gone bad.
  4. billybravo
    1,045
    cheers mate is it known for injectors to go bad like that if one is messed up should i get uprated ones?
  5. billybravo
    1,045
    i moved the injectors over 4 to 3 and the code moved also to n32 so its got to be the injector
    now does anybody have a std one in the northwest area or know where i can get one asap
  6. madkebab
    madkebab Member
    418
    Glad you know that it is the injector mate. Dont think you need uprated ones unless you go for a big turbo setup.
