Help please with low tyre pressure warning
CharlesM Oct 14, 2008
  1. CharlesM
    CharlesM New Member
    Anyone know how to disable the low tyre pressure warning. Even tho' my tyres are at the correct pressures the warning is on, and when the warning is on you cannot read the driver's computer readout. Sorry, should have explained - the car is an eighteen month old RS4 9the best car I have ever had!)
  2. klauster
    klauster Well-Known Member
    1,188
    112
    go into the computer using your steering wheel buttons, should be able to get to a menu that allows you to reset your tyre pressures.
  3. A6UYC
    A6UYC milf
    35
    I may be well off the mark but have you tried filling them all at the same pump? may a differant air in some.
  4. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    And if after doing that the warning is still there it suggests you may have a faulty wheel sender - best bet is to get someone with VAG-COM to check for fault codes.
  5. Sno
    Sno don't knock it til uv tried it
    39
    needs to be reset with ignition on and engine not started.
