Help please with climate control
cossie Sep 6, 2010
  1. cossie
    cossie Member
    79
    The digital display on my climate control has been cutting on and off but my ac, climate and fans all still worked. Now i got a 2nd hand replacement unit, fitted it and the display all lights up great but now when i press the air con button my air con doesnt come on. So i refitted the original and the air con came on again then refitted the replacement and again it all lights up great but no air con? My A4 is a 1996 model and as far as i know the replacement is from a 1998 model, would this make a difference or is it a case of the 2nd hand replacement is also faulty? The newer unit did look slightly different but it pluged in and fitted fine and as i said it all lights up great. Any suggestions on how i can get my air con to work with the new unit would be greatly appreciated as now with all the faffing about my original unit wont display at all now and it wont let me turn the fan speed up or down!!! Thanks chaps.
  2. alex-qts
    alex-qts Member
    59
    not sure about your issue but mine randomly stops and starts, the screen stays on but the buttons dont work! i have been meaning to pull it out for ages!
    maybe you could try connecting the new/old unit and then resetting the ECU, im not sure if this would help - maybe the ECU needs to find the new unit??
  3. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    There is a known issue with these. If you take it apart there is a grey ribbon cable connecting the main board to the front panel pcb. These are infamous for dry joints. There's a 'how to' on audiworld somewhere (which I can't find right now) it's easy enough to get it to bits to re-solder the dry joints on the back of the ribbon cable connector.
    Good luck
    Si.
  4. NineNails
    593
    Just to add... I meant this info for your original unit with the dodgy display. It might be the problem with the secound unit but can't be sure
    Si.
