Help please. Windscreen wiper problem ( not the usual ceased spindle problem )
lawrieh Aug 21, 2010
  1. lawrieh
    lawrieh New Member
    When I switch the windscreen wipers on they often do not work.
    If I get out and either wiggle them or raise the wiper arms half way and let them slap back onto the windscreen this always fixes the problem.
    When they work they are as good as new with a brisk, powerful action so I am pretty sure its not the common ceased spindle problem.
    I have reseated the fuse and relay to no effect.
    Has anybody else encountered the same problem? I suspect they are controlled by commutators ( slip rings ) in the motor assembly, has anyone tried to fix/repair such problems.
    Thanks in advance .....
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    try pulling motor assembly apart, i had a similiar problem and found rings/track covered in dirty grease
    cleaned it up and all worked perfectly
