help please whats this dash sign could it be a doggy MAF
dre_S3 May 13, 2012
  1. dre_S3
    dre_S3 Member
    756
    39
    Had this sign pop up with my esp sign but that's gone of now and this one has stayed on
    i had my MAF of while i sorted my TIP i put it back and forgot to connect the MAF but then relised before i drove off and connected it i have relised on my boost gauge that im only boosting to 8 psi to can this be a doggy MAF or can it be my boost gauge playing with the electrics only fitted it yesterday im puzzled
  2. murran
    murran Well-Known Member
    1,545
    39
    did you start it up with the airmass unplugged?
    probably just need the fault codes deleting.
    esp light would have come on cus the esp needs the engine load signal (partly calculated using the airmass signal) to work. now its plugged back in it will go off on turning the ignition off and back on. will still have an intermittent fault registered in the abs/esp for it even if the light is off. best to clear that too.
    but the airmass being unplugged for a time will have registered a fault code in the engine ecu until its deleted.
  3. dre_S3
    dre_S3 Member
    756
    39
    That make sense thanks for you help :) can I buy anything I can pug in a reset the faults
  4. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    Check the VCDS section and see if any members are local to you,who can let you clear the faults in exchange for beer/whatever
  5. murran
    1,545
    39
    apart from the obvious vagcom purchace, or finding a forum member with vagcom local to you, willing to help.....
    these are good and very handy for resetting codes and service lights, tho you cant view actual data/values and reset throttle bodies.
    AUTEL MAXSCAN VAG405 | eBay
    i have one. (my mates borrowed it atm!)
  6. dre_S3
    dre_S3 Member
    756
    39
    Ok thanks for your help peeps much appreciated will prob buy a tool as I can see myself needed one in the future to :)
  7. s3mad_dude
    s3mad_dude Noggies ruuuule!
    614
    79
    If you leave the battery disconnected for 30mins would that do the trick?
  8. dre_S3
    dre_S3 Member
    756
    39
    Ok thanks will try and disconect the battery worth try
  9. dre_S3
    dre_S3 Member
    756
    39
    It worked mate :)
