Help please what do thes dash lights mean?
Gavlar Feb 25, 2011
  1. Gavlar
    Gavlar Member
    312
    45
    As title says I have two dash bored lights that come up at the same time. Could someone please tell me what they mean and what's wrong with my car [​IMG]
    Obviously ignore the handbrake light. What do the 2 yellow ones mean?
    Gav
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    The one that says ABS is saying there is a fault with the ABS system.
    and the other one i'm not to sure.
    Got your car manual to hand?
    EDIT:=- The one is ESP I think.
    Also, get VCDS on it and check for codes.
  3. quattrojames
    14,060
    583
    Dash bored - awesome!
    They are indeed the ABS and ESP lights, meaning there is a fault with the car, most typically brake light switch or abs sensor. Do the brake lights work ok?
    If so then I'd try and get the car scanned to give you a better idea of what's wrong.
  4. docurley
    4,072
    87
    If it's not a rear bulb then it will be the brake switch which is around £20 and 30 min to fit.
  5. Gavlar
    Gavlar Member
    312
    45
    It turns all my traction control off??
  6. quattrojames
    14,060
    583
    ESP works by controlling the brake circuit in parts, if there is a fault with this then it will turn ESP off too as a failsafe.
  7. Gavlar
    Gavlar Member
    312
    45
    Surely it's not goin tob a bulb then?
  8. Gavlar
    Gavlar Member
    312
    45
    Where abouts is this and is it hard to do yourself?
  9. quattrojames
    14,060
    583
    Its on the brake pedal. I've a pdf you can have if you want.
    Have you checked to see whether the brake lights are working?
  10. Gavlar
    Gavlar Member
    312
    45
    What's a PDF mate?
  11. ScottD3
    15,164
    1,123
    A document file like windows word document but you can't edit it.
  12. Gavlar
    Gavlar Member
    312
    45
    What do I do with it. Sorry for my ignorance lol
  13. quattrojames
    14,060
    583
    Its a guide to help you change the brake light switch!
  14. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    :banghead: ......we have the Technology!
  15. Cabbyfan
    Cabbyfan Active Member
    840
    34
    You open it like a Word document, using a progream called Adobe Acrobat reader usually or just google PDF reader and you will be sorted.
  16. Gavlar
    Gavlar Member
    312
    45
    Oh I see lol sorry. Yeah if u could. Thing is it's very intermittent which doesn't help
  17. quattrojames
    14,060
    583
    PM me your email address and I'll send it over.
    I'd get it scanned though before you start changing things at random.
