Help Please - So stuck with this!
A3DOL Sep 25, 2009
  1. A3DOL
    A3DOL Member
    97
    So fine starting when cold but when warm turns over and over then judders when eventually firing.
    lvedHave had x2 clutch and flywheel transplants - Not resolved.
    Gearbox and engine mounts - Not reolved.
    Could it be this....
    http://cgi.ebay.co.uk/TDI-PD-Diesel...s_SM?hash=item2ea7818c94&_trksid=p3286.c0.m14
    Think it did it before fitting this unit but since fitting its got worse. Could the sensor be knackered anyway and this unit has just made it worse?
    Q. Is this unit telling my ECU the fuel is cold when its hot and causing it to start sh1t? It only EVER judders when warm. ALWAYS starts fine when cold.
    My only other thinking is for a re-map. Could the ECU be on its way out?
    Please Please help. So fed up with it.
    :sob:
  2. DaveA3-TDI
    DaveA3-TDI Member
    249
    I would like to bet that it is your starter motor that is the problem, I had the exact same problem as you and changed allsorts first. Spoke to a audi mechanic who acutally knew what he was on about and told me it was my starter motor. Had the starter motor replaced and now it starts on the key cold or hot. Hope this helps.
  3. NJI161
    NJI161 New Member
    Not related to your problem but did that ebay chip improve performance?? and what effect on mpg?? Is it the difference comparable to a remap?? ta.
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    I take it that it has been tested using a diagnostic machine? Was there anything found?
  5. A3DOL
    A3DOL Member
    97
    No faults found on testing.
    TDi chip has made no difference to performance.
    Mmmmm, starter motor. Any other ideas?
  6. tates1979
    tates1979 Member
    52
    You have identical symptoms as my 1.9tdi.
    I too have had my DMF replaced - nada.
    On DaveA3's advice(cheers by the way) I have ordered a replacement starter.
    I'll keep u posted on my progress. Failing that, the ECT sender?
  7. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    temp sender unit?
    Maf sensor?
  8. Khufu
    5,704
    31
    ECT sensor was going to be my 1st suggestion too. It wont always report fault if it is within parameters but still could be reading wrong.
  9. A3DOL
    A3DOL Member
    97
    Tried the MAF sensor - not the problem.
    An absolute nightmare. Even to the point of juddering when stationary. New DMF so not that!
  10. Khufu
    5,704
    31
    what year & mileage?
  11. A3DOL
    A3DOL Member
    97
    2004 (54) 1.9 TDi 68'000 miles.
    Fully serviced etc and looked after.
    How could it be the starter? Not sure how that would cause it.
    If it is the fuel temp sender it makes sense. Are they dealer only?
  12. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,074
    61
    Maybe EGR valve problem? Or cleaning the intake manifold could help?
  13. A3DOL
    A3DOL Member
    97
    Have checked EGR too.
    Have also checked all the air intake for leaks.
    Only happens when warm, never when cold. Must be either ECU or a sensor somewhere.
    Interesting to see whap happens with tates1979 starter motor. I wonder if the bendix is not engaging properly. Wouldn't this happen all the time though and regardless of how warm it was?
  14. DaveA3-TDI
    DaveA3-TDI Member
    249
    If your car is hard to start when hot but starts fine when it is cold and drives ok then you have the same problem I had and I know you find it hard to believe but a new starter motor fixed my problem. I spent many hours searching forum posts and no one had a cure for this problem, only person that got it right was the audi master tech mechanic I managed to find. I believe it is something to do with cranking speeds and hot start/cold start.
  15. A3DOL
    A3DOL Member
    97
    Thank you!
    At long last someone who has experienced the same but with a solution!!
    Was your replacement a Audi original or aftermarket and how much was it.
    Thanks again!
  16. DaveA3-TDI
    DaveA3-TDI Member
    249
    Yes it was a genuine Audi replacement and was about £136 I think. I didn't believe the mechanic at first and thought how can it be the starter but he said that if it didn't fix it I wouldn't have to pay so I didn't have anything to loose really as tried other stuff first and that didn't work so I trusted him and it worked :)
  17. A3DOL
    A3DOL Member
    97
    Best get one on order then!
    Cheers again mate. Thought this was a never ending problem. Wish I hadn't spend over a grand so far though!
  18. DaveA3-TDI
    DaveA3-TDI Member
    249
    Let me know what happens ?
