Help please - Running Live wire through bulkhead.
equinoxsu Sep 10, 2009
  1. equinoxsu
    equinoxsu New Member
    hi there peeps .
    I can't find anywhere to run my power wire from the battery into the bulkhead to run an amp any suggestions where i should make a whole or is there another way ?
    thanks
  2. s11pyk1234
    s11pyk1234 New Member
    i think i ran mine through somewhere near the pedals when i had my tdi?
  3. marcyp
    marcyp Only me
    126
    if you look under the pannel were the pollen filter is theres a unused gromit make a little hole and poke it down there with a coat hanger and i comes out behind the glove box its easy to find
  4. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    As Marcyp says here's a pic:
    Pull the cable through from the footwell otherwise it's pull the grommet out.
  5. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    I personally would go through the box which the loom goes through into the car as its less likely to leak. Just take the lid of the box off, and there is a blanking gromet on the side. Punch a hole in it and then pull the cable through. From inside the car, take off the steering wheel undertray and you will be able to get the cable and run it where you want to.
  6. equinoxsu
    Thanks For your help Guys
    Much appreciated . :)
