Help please, RNS-E Bluetooth upgrade
Herald Aug 15, 2008
  1. Herald
    Herald New Member
    Hello. I have an allroad C5 which came with RNS-E from the factory. I have installed an OEM Bluetooth module and have it working fine. The only thing I can not get it to do is to upload all the phone numbers from my Nokia 6300 and display them on the screen, as it would do in an A3 or an A4. It will dial out from the phone, receive calls by pushing the big RNS-E knob and the call quality is great. Is this because the base car is too old, or have I not got the right coding? Any help most appreciated!
  2. s8craig
    1,753
    55
    It would help if you posted the following....
    phone module part number
    codings for phone module
    coding for RNS-E
    software revision on the RNS-E.
    Also maybe the firmware level of the 6300.
  3. Herald
    Herald New Member
    Thanks. Part Numberr is 8P0062335Q, Software on RNS-E is 0550, I need to get to a machine to find out the coding. The phone works with another friends Audi S4 B7 properly if that helps rule out the phone.
  4. Herald
    Herald New Member
    I have finally got my car to a machine. The RNS-E is 4B0035192P, H44 hardware and 0550 software. The coding of the unit is 509218. The Bluetooth unit is 8P0862335Q, H26 hardware and 0350 software, coding 11802. If anyone can shed any light on what I have done wrong, I would be most grateful.
  5. s8craig
    1,753
    55
    Well your coding is wrong
    0509718
    and
    0011822
    Make more sense for a car with a MFSW/TV/CD changer
  6. Herald
    Herald New Member
    Thanks very much S8Craig, right as usual! It now works fine and I am very pleased.
