Help please!!! I've killed my car. Engine ecu u the swanny!
scottie123 Nov 7, 2010
  1. kkp0897
    kkp0897 Active Member
    768
    45
    Sorry to hear about all the problems Scottie - I don't have much to offer as it seems the responses above as far more technical than I could ever offer. Does anyone know of a good vehicle electrician in your area that could come out and have a look? - AA\RAC Technician? - Bung him a couple of extra quid to have a proper look?
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    problems sorted already mate, scotties an engineer to trade so is pretty capable anyway
  3. mike foster
    3,967
    Can you post the answer to the problem, or ask Scottie to do so please ?
    It will help others if they get in the same situation.
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    it was a connection problem within the wiring of sorts, the piece was replaced and all is well now :)
  5. mike foster
    3,967
    Thanks mate - ( which piece? ) presumably a further update will be available so that others can understand what, and what not to do if they wish to do the same mod ?
  6. kkp0897
    768
    45
    Good for him - hopefully with enough time to keep his nads intact....
  7. mike foster
    3,967
    :wtf:???
  8. Khufu
    Khufu Well-Known Member
    5,704
    31
    Ah, its sorted? Good news! Details would be nice LOL
  9. PH1L
    PH1L Gievf Buckets
    3,851
    40
    it was a simple wiring fix relating to the back emf produced when his relays shutdown true facepalm moment
  10. mike foster
    3,967
    Reverse diode required but not fitted ?
    Which part did the back emf knacker ??
  11. PH1L
    PH1L Gievf Buckets
    3,851
    40
    just frazzled a wire internally unsure of which diode wasnt fitted tbh if it was me id have overlooked it too
  12. Khufu
    5,704
    31
    "XXXX laymen's terms, do you speak English?" LOL
  13. mike foster
    3,967
    We know which diode wasn't fitted - the one on the relay !
    What we don't know, and what we would all like to know, is precisely what internal communication wire was frazzled because of the relay !
    I thought that all automotive relays had built-in diodes to combat back-emf problems but obviously this is not the case. The voltage on the coil of a 12 volt relay can spike up to 1000v for a milisecond when switching off hence the design requiring a reverse biased diode across the coil connections to short out this voltage.
    We can all imagine what damage that spike can do, albeit for a milisecond, to a computer !
  14. N8
    17,163
    718
    Whats the latest sorry to hear Scottie.
  15. PH1L
    PH1L Gievf Buckets
    3,851
    40
    He wasn't using automotive parts for the link it was in the power wire he isn't fitting a conventional led setup either they're from Mercedes all will be revealed in time its not my place to its his car and work. I merely came along to tell you the issue is fixed which I found out when I was in contact giving him wiring diagrams
  16. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,236
    331
    hey scottie did you have any luck getting your car sorted after mate ?
  17. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Yes mate all sorted now:)I now have some real marmite led dels!
  18. FranA3
    7,236
    331
    good stuff mate glad you got it sorted
  19. scottie123
    1,972
    You know how it is fella.molding ain't true Modding unless you break something in the process :)
  20. FranA3
    7,236
    331
    lol i know what you mean matey ive done it loads of times haha looks good tho
