Help please guys...
S3featesV9 Mar 29, 2012
  1. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    Just been for a drive to find some fuel, everywhere is closed.
    And noticed my idle was quite high, about 1000rpm. Popped the bonnet to find a boost leak, the pipe that comes off the inlet mani on the LHS if ur sat in the car.
    Would this cause my idle problem? Also where stocks that plastic pipe? Kinda want it ASAP
    Cheers guys
  2. S3featesV9
    1,032
    12
    Just tried allparts, they dont. Is it an Audi dealer only part?
    Is there a quick fix I could do until I get one?
  3. Dani_B19
    9,343
    394
    Forge do a replacement.
  4. S3featesV9
    1,032
    12
  5. S3featesV9
    1,032
    12
  6. Dani_B19
    9,343
    394
    No mate both wrong, on fone or id post link, they do another one for you engine, need to be 3 connections
  7. S3featesV9
    1,032
    12
    Haha. Bummer. I ordered both already. Oh well. Can replace them anyway. Just drove to the misses house and had emissions light come on. Pulled over and scanned the car, 2 faults one was system too lean, other one idle too high.
    Is this due to the split pipe? Is car alright to drive?
    I cleared the faults and finished the journey and re scanned and nothing had reappeared.
    All input and help is grateful, also can someone link the correct pipe I need please :) thaaaanks
  8. Dani_B19
    9,343
    394
    You cant replace the second one as its for my apy engine, cars bot rwally good to drive as itll be pullin in unmetered air under idle n leaking under boost, but if the cars a dailt then youll have to until the replacement some.
  9. S3featesV9
    1,032
    12
    Second one doesn't state what it doesn't fit, so guessing its alright for BAM.
    The first one states it fits BAM and AMK only, there is another option for APY. And it's exact same as the hose
    Attached to my hockey puck.
    From looking at my split pipe, the second one is what I need to replace the split one?
  10. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Don,t listen to Dan he is a special child.....:undwech:
  11. S3featesV9
    1,032
    12
    Any idea why this split pipe would case a running lean fault?
    The second pipe is what I need isn't it? You advise to not drive Car or just use when I really need too until pipe arrives?
    A bit worried as I have a brand new turbo and dot want my system running lean
  12. Dani_B19
    9,343
    394
    Sod yu dave haha :), shouldnt you be making my brackets anyway :) lol.
    Seriuosly though, the first silicone part doesnt have the proper bam setup to allow for the pcv and brake server pipework, only the brake server outlet.
  13. S3featesV9
    1,032
    12
    First one isn't brake vacuum. It's cam breather!?
  14. Dani_B19
    9,343
    394
    Sorry mate i meant second one.
  15. badger5
    9,553
    2,027
    its off the intake manifold so is a boost and vacuum leak
    extra air, more than maf saw, for which lambda will be adjusting for, so a lean code is possible yes.
    you will see block 032 at a very high +ve% adjust.. 25% and it stick MIL light on
  16. S3featesV9
    1,032
    12
    Is it alright to drive? Kinda need to get about, have a push bike but if cars ok to use then ill use it.
