HELP PLEASE!!! FOG LIGHT HELL!!!
jmw1200 Oct 11, 2009
  1. jmw1200
    jmw1200 New Member
    Hi fellow Audi Strokers
    In the process of converting 06 Sportback (2.0 TDI Sport) to an S-Line version.
    Had a second hand s-line front bumper repaired and resprayed etc, and it looks champion (especially with the big black grille). Well chuffed.
    Here's the problem:
    S-line bumper had to have s-line fog lights and fog grilles, but the plugs that come with the fogs, have a different plug than the plug from the car's lighting system. Hope this makes sense.
    The guys who fitted it, said i would need a retrofit plug wiring conversion kit, which i could buy from fleabay. However, i can't find it anywhere.
    Anybody else encountered this problem?
    Thanks in advance :sos:
    Jmw
  2. Lee_R
    Lee_R Active Member
    2,499
    12
    Yeah you can also buy a "repair wire" kit from Audi themselves to do this. You could always bodge them together with bullet connectors then wrap a load of insulation tape round them, job done!
  3. jmw1200
    jmw1200 New Member
    Lee R. Top man.
    Any idea exactly what the part number is for the AUDI WIRE REPAIR KIT? or the exact name?
    Cheers :yes:
  4. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    That is the name mate. It's just a single wire that has the normal terminal ends that fit into the connectors used on the car. There are different sizes though but I'm fairly sure most of them are the same.
    Found this site:
    http://www.nsxjr.com/Audipins.html
    And on there:
  5. jmw1200
    jmw1200 New Member
    Thanks Stazatron.
    You are the man.
    :applaus:
  6. Khufu
    Khufu Well-Known Member
    5,704
    31
    i used the exising wires - using thin needle or such, you can remove wire from the holder by bending the locking tab back. You can then bend the tab back out and insert it back into the new holder.
  7. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    When I did the conversion I cut the old plugs of and soldered new repair wires on.
    Fog plugs x2 3D0941165A
    Fog repair wires x2 000979244
