help, please decipher vagcom error codes!
skanky Aug 10, 2006
  1. skanky
    skanky Member
    387
    any idea what the following vagcom errors are and how to fix, i have a 1999 A3 1.8t sport and did the autoscan (im using 311.2-N):
    ..the other addresses have no fault reported.
    thanks!
    EDIT: removed other errors as they dont seem to be coming back but the above one still does.
  2. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    While I am no expert, the only one that I think might be a problem is the temp sensor as these are prone to failure. I would clear the codes and see if they return. The intermittent nature of most of the faults indicate that something happened once or twice and set the codes.
    You didn't say your car was misbehaving. So I am assuming all is working well except these codes are stored. Again, I'd clear them and then in a day or two - after some driving, I'd scan again to see if they returned.
    -Bruce-
    Ross-Tech, LLC
    bruce@Ross-Tech.com
  3. skanky
    skanky Member
    387
    right, cleared them all and the only one that came back was:
    17967 - Throttle Valve Control part (J338): Fault in basic settings
    havent gone for a drive, yet (quickly tried clearing them before heading off to work this morning), but any ideas/suggestions? Connection to the Throttle Valve Control part (J338) has come loose or something basic like that?
    cant say i've had the car long enough to know that something is wrong, if i didnt scan it, i wouldnt have thought "ooh wait, the throttle valve control seems a bit off"
  4. Sebastian
    Sebastian Member
    286
    First off, this should be helpful...
    http://wiki.ross-tech.com/index.php/17967/P1559/005465
    ...or in other words: Perform the Throttle Body Adaptation
    The airbag codes are a bit scary, but could be caused by a disconnected battery and the same applies for the central locking codes (except they are not scary).
  5. skanky
    skanky Member
    387
    sounds silly/basic: but how do i perform throttle body adaptation?
  6. Sebastian
    Sebastian Member
    286
  7. skanky
    skanky Member
    387
    okay had a read through that, im assuming i have a NDBW car, i did notice this:
    now whats a DTC? and also
    ..whats an ISV?
    sorry, but im a bit basic with cars :)
  8. Sebastian
    Sebastian Member
    286
    Correct, your 1.8T AGU engines uses MVB (Measuring Value Block) 098 for the TBA (Throttle Body Adaptation). Make sure that no DTC (Diagnostic Trouble Code) is stored, the 17967 doesn't matter in this case. ISV means Idle Stabilization Valve.
  9. skanky
    skanky Member
    387
    well i did have another engine DTC but cleared it and it hasnt come back, will take it for a test drive then check it again to be sure.
    would my car have a ISV?
  10. Sebastian
    Sebastian Member
    286
    Have you done the TBA yet? No, I don't think yours has an ISV.
  11. skanky
    skanky Member
    387
    no not yet, im at work so im in "gathering info" mode atm..
  12. skanky
    skanky Member
    387
    i tried the throttle adaptation using vagcom, selected 098 as detailed here http://www.ross-tech.com/vag-com/cars/throttlebody.html --clicked on go then switched to basic settings.
    it went from idle, part throttle then errored. for my troubles i've gained another error, see below.
    doh! :/
  13. Sebastian
    Sebastian Member
    286
    Take out the throttle body, clean it and check connectors/wiring - then do the TBA again.
