S
Scottamdaddy
Guest
Hi guys so as some of you may know from a previous post of mine one of the jobs to tackle on my b6 is to fix the break pad warning light. I have checked the volts on both side passenger no problems driver has no power to the plug at all. Tried the paper clip trick no luck. The pad wear cable looks like it joins the abs feed and then goes into the wheel arch the metal part of all places can any one tell me where the cable goes or if there's a seperate plug for the drivers side I would rather fix the issue rather than bodge it but it's looking like I may have to cut the wire on the green plug inside the car and ground it to get rid of the light. Any suggestions would be great
Thanks in advance guys
