Help Please ASN - Brake light trouble
sniffy_smiffy
Every time i attempt DIY i regret it.. I am so annoyed.
Simple Stuff intially:
- Both rear brake lights stopped working (High Level Boot brake light OK)
- Brake light switch faulty when scanned with VAGCOM
New OEM Brake light switch fitted (local mechanic)
Still no brake lights, so I removed the rear drivers side cluster only to find bulb is OK & new one does not work either ?
When fitting the cluster back again realised the screw was no longer there to screw the unit back in ?
It must have dropped down inside the car chassy somewhere and I cannot find it? I will have to buy another from Audi i guess? How annoying Ahhhhh :banghead:
Any useful tips for my next attempt ?
I checked Fuses #7 ESP & Brake light switch & #14 Brake lights. These were Both OK
Not sure what to try next folks ???
Any guidance would be hugely appreciated?
Regards
Smiffy
This is my latest set of faults from VAGCOM
Chassis Type: 8E - Audi A4 B6
Address 01: Engine
Controller: 8E0 909 518 AL
Component: 1.8L R4/5VT 0003
Coding: 0011501
Shop #: WSC 63251
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04475
Shop #: WSC 06435
1 Fault Found:
00526 - Brake Light Switch-F
36-00 - Open Circuit
Address 09: Cent. Elect.
Controller: 8E0 907 279 C
Component: int. Lastmodul RDW 0606
Coding: 00001
Shop #: WSC 63251
1 Fault Found:
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Address 46: Central Conv.
Controller: 8E0 959 433 BD
Component: Komfortgerát TBF 1511
Coding: 07115
Shop #: WSC 63251
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent
Address 56: Radio
Controller: 8E0 035 186 L
Component: concert II GRO 0001
Coding: 01001
Shop #: WSC 63251
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Byzan A4 said:
brake light switch incorrectly fitted IMHO
Cheers Byzan I have heard they are quite tricky to fit. Will probably have to buy another as they can break easily ?
I have a pdf guide for fitting the brake light switch. PM your email to me and I'll send it.
Thanks for help chaps I have a nice shiny new pdf guide in my inbox ready to give it a go, kindly provided by Mr QuattroJames. Will post how it goes, hopefully it will just be the switch. Regards smiffy
I quattrojames,
I have the same problem that is described in the topic.
Can you send me the great PDF, please?
Thanks,
Rui Teixeira
