HELP: People of ETKA, I need some part numbers!!!!!
Prawn Jan 30, 2012
  1. Prawn
    11,575
    3,546
    Right folks, all has been going fairly OK, aside from another dead gearbox, but tonight I've sprung a leak!
    I need part numbers for the following bits, all for an AMK S3, so I can just order it from TPS and replace the whole bloody lot to avoid a leak coming back
    1. The plastic multi way fitting that goes onto the end of the head, mine is different being an AGU, I need an AMK one which I THINK is a different angle to mine
    2. The short bent hose that comes off the back of the above plastic fitting, I would make one up myself, but it's very short, and reduces from 25mm down to 19mm, so I need to get the right one, again for an AMK S3
    3. Also, if possible, the 16mm hose that comes off the bottom of the above plastic fitting too, and I think connects to the heat exchanger, Can't remember exactly, but it's the one that comes off the bottom!
    If anyone can help I'd be SERIOUSLY grateful! I've worked like crazy to get this car ready for mapping this weekend, and this is now the only thing stopping me, and I don't want to bodge it and stick some radweld in there!
    Cheers folks
    Prawny
  2. Prawn
    11,575
    3,546
    haha, ignore my dodgy photo edit above, silly small netbook screen!
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    I think this is the plastic part mate, just hunting down the rest:
  4. Westy
    17,443
    1,105
    This is the rest of the cooling system if you see anything that looks like the part you need?
  5. Prawn
    11,575
    3,546
    Those two bits I think dude, and I've just noticed, number 16 too I think! the other one from the heat exchanger.
    It's so hard to read, because the layout in the pic is ko3 not ko4!
  6. Westy
    17,443
    1,105
    Ok mate, some part numbers:
    The top hose in the above pic is 8L9 121 157 D
    The bottom circled hose is 8N0 121 088
    Number 16 hose is 8L9 121 096 C
  7. superkarl
    superkarl MAN OF STEEL
    9,553
    2,453
    this part (for amk):
    is part number 06A 121 132 AP - i paid £11.28 with 8% discount from TPS.
    replaced mine about a month ago ya see. there is 3 different ones when i enquired at audi and tps. this was the right one for my AMK with the 'AP' at the end.
  8. 666markyboy
    666markyboy Well-Known Member
    1,219
    52
    i hope your joking about the radweld
  9. Prawn
    11,575
    3,546
    Joking about what matey? I said I dOnt want to bodge it with radweld
  10. Prawn
    11,575
    3,546
    Thanks for your help folks, all ordered at TPS, parts in tomorrow so should be sorted then.
    Thanks muchly.
  11. bigpapasmurf
    bigpapasmurf Member
    88
    Hey hey, Ive got a similar problem in my AMK S3 8L:
    Its coming out of the sensor housing bit. Is it likely to be the housing or the sensor? Does anyone know what the sensor part number is for the AMK? When replacing the unit do you loose massive amounts of coolant?!? Sorry for all the questions, but any help would be great...
