Help! Passenger's window won't close! VCDS Code.
SAiLO Jan 2, 2010
  1. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Hi guys,
    Something happened and I can't close the passenger's window.
    Got this error code through VCDS:
    00933 - Electric Window Motor; Passenger Side (V148)
    012 - Electrical Fault in Circuit
    Did the testing - When trying to Lower/Raise the window I only hear a tick in the door but no movement of the window. VCDS says "inactive" with both test.
    Thought it might be a fuse but it wouldn't make any sound then, am I correct?
    Which fuse is responsible for the window motor on passenger's side
    It might get unpleasant when it starts raining!
    There's a 3inch gap and (touch wood) I hope no one will try to find their way inside.
    I will try to take the door card off tomorrow, unless someone's got a solution.
    Any help appreciated!
  2. Paul Laird
    Paul Laird Member
    137
    i think the motor is at fault m8 or could be regulator is faulty causen the motor to jam up
  3. SAiLO
    1,078
    62
    I'll try to look at it tomorrow, remove the door card and see what is the cause. Hopefully it won't be anything serious.
  4. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    try holding the lock button and see if that shuts it ?
    if it does, then its a switch fault.
  5. SAiLO
    1,078
    62
    I've tried both switches and neither of them shut the window. As for the lock button, holding it does not close either sides.
  6. kaz219
    1,808
  7. SAiLO
    1,078
    62
