Help... Overheating!
benberry Jul 3, 2013
  1. benberry
    benberry Member
    37
    Hi Guys,
    I was working on a separate problem on the Avant yesterday, had the engine running whilst I worked in the boot.
    After about 30 mins I noticed smoke/steam coming out from under the bonnet.
    When I opened it up I could see the coolant tank was bubbling over so I turned it off to investigate.
    It turns out that the fans weren't running at all, hence the overheat where not moving.
    I checked the temp gauge and never went over 90 but foes drop when it cools down.
    The fan does work when I turn the aircon on?
    What do you think is broken?
    Ben
  2. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Check the fan fuse / relay.
    What engine is it?
  3. benberry
    benberry Member
    37
    Its a 3.0 v6
    Which fuse do you have in mind?
    Fan does work when Aircon is on but doesnt seem to detect its getting hot and kicking in on its own?
  4. AlexGSi2000
    1,464
    199
    Are there two fans on the 3.0 V6?
    There is an independent fan on my 2.5 that operates regardless off the air-con (this is a viscous fan I know, but thought other engines had electric fans)
    On my 1.8 there was a relay / control unit next to the main fan itself.
    Check your instruction manual for fuse locations.etc
  5. benberry
    benberry Member
    37
    Just a single fan as far as I can see, works fine.
    The problem I've got is it doesn't recognize its getting hot and isn't kicking in like it should, only when I turn Aircon on!
  6. mattyb6
    mattyb6 Active Member
    977
    75
    Put a new stat and temp sender in, and check fuses like above.
    Does your vents in the cab blow hot air? Because if not it could be a sign the water pump is failing/ and head gaskets.
    flush the water through aswell. Could have an airlock aswell.
  7. pauldazzle
    pauldazzle Well-Known Member
    1,136
    82
    Coolant temp sensor failure is extremely common which resulted in VAG revising the part.
    It has 2 outputs one to the gauge, & the other to the ECU. If the ECU feed is reading low engine temp the ECU won't turn the fans on.
    If you have the old black type CTS it's worth changing to the revised green type ( fit genuine VAG part only) as it will fail at some point.
  8. benberry
    benberry Member
    37
    Ok thanks. I take its ok to drive still as I can still turn the fan on manually with the AC.
  9. Mike B
    Mike B Well-Known Member
    1,101
    40
    There must be 2 fans
  10. benberry
    benberry Member
    37
    Really? I can only see one?
  11. Mike B
    1,101
    40
    The aircon needs its own fan cos the engine may not be hot but the interior is .
  12. benberry
    benberry Member
    37
    The aircon kicks the fan on when you turn the air con on, it' off otherwise - would indicate it uses the same fan?
  13. Mike B
    1,101
    40
    They are independent systems.No way can one fan cool the aircon rad and the engine coolant rad.On my 2.5tdi the aircon fan is smaller less obvious and mounted to the drivers side alongside the large engine fan.Could be that there is a temp sensor in the rad which has failed .Diagnostics should tell you
  14. hades-
    9,481
    646
    the aircon fan wont stop it overheating
    when you drive does the temp gauge go up and down ?
    does it sit at 90 all the time ?
    id get it looked at if its the WP and it goes fully your looking at cooking the top end and turbo
  15. Mike B
    1,101
    40
    The fan has failed.Must be a sensor.Hapend on wifes Bora last year when they let it idle for the MOT .The sensor in the rad had failed.It would soon boil if the w/pump u/s
  16. benberry
    benberry Member
    37
    I'm getting it booked in on Tues to get checked.
    In the meantime I need to drive to Cumbria and back (600 odd miles)!
    I've left it to run with a warm engine and fan on for 10 mins and seemed to stay cool. When I tried to do the same experiment but with no aircon it started to get hot.
    The fan that blows is definitely the main coolant fan so surely as long as that's running full pelt it will work? Its a 3.0 v6 NASP so no turbo.
    I'll get the sensor or whatever changed but manually for now will do.
  17. hades-
    9,481
    646
    depending on what has failed even with fan on it could still over heat
    i wouldnt risk 6 miles let alone 600 with it the way it is
    it it is the pump on its way out it could fail fully same as mine did
    and i have to have a new head turbo etc
  18. Mike B
    1,101
    40
    Dead right. In this weather more so.You know there is something wrong needs fixing
  19. AlexGSi2000
    1,464
    199
    +1
    600 miles with a cooling issue could spell disaster.
    If you absolutely need to drive to Cumbria, make sure you can cool the engine by whatever means possible.
    (remove front grille, remove plastic engine covers, keep interior blowers on a high heat.etc)
    Sounds extreme, but that's what I'd do!
  20. Mike B
    1,101
    40
    If its just a sensor it would take 20 mins to change
