Help - overfuelling mystery
salsheikh Nov 12, 2010
  1. salsheikh
    salsheikh New Member
    24
    My AUQ engine has recently started to overfuel.
    So far the lambda sensor/MAF/Injectors/FPR have all been changed but still overfuels.
    Did a smoke test and had a boost leak from the intercooler MAP sensor but this is now fixed.
    The car is on a standard oem map but the mechanic could not adjust the fuelling to stop it from overfuelling.
    Been told that the head will have to come off for further investigation.
    Any ideas what it could be? no fault codes showing either
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Have you got any logs?
  3. salsheikh
    24
    sadly no mate. car is with nick at R-tech and he is trying to sort it.
  4. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    map sensor reporting too high throughout the rev range?
  5. salsheikh
    24
    wouldnt this show up on vagcom?
  6. Mpathe
    Mpathe 1st gear
    394
    what makes you think it's overfueling?
  7. bengal
    bengal Member
    537
    Im surprised the temp sensor hasnt been mentioned as when they go bad they can cause the car to run on cold start which it will then overfuel. They dont always show up on vag com or on the temp needle as a problem.
  8. salsheikh
    24
    will get this looked at, thanks.
  9. Broken Byzan
    13,237
    466
    TBH Nick is pretty switched on, i cannot imagine he has left simple things to chance. What gives the impression it's overfueling?
  10. salsheikh
    24
    this is what Nick said is the problem.
  11. salsheikh
    24
    update,
    compression test - ok
    turbo oil seal - not looking good as oil found in pipes so turbo is gonna be sent to be checked and repaired.
    not loosing any coolant at all or much oil before this happened.
    coolant sensor changed.
    thanks for all the replies guys. will update once i know more.
  12. GeeJay89
    GeeJay89 New Member
    Could be an obvious question, but what's the temperature gauge at, 90? Anything else and it could be the stat, which in turn would cause it to overfuel. Got an extra 60 miles for £25 of petrol once I changed it.
  13. salsheikh
    24
    temp always sat at 90 on my car. i was getting about 250-300 to the tank full
    Nick said the turbo shaft has got lots of play in it too and gasket is fooked.
    will get this repaired by turbo dynamics i think he said.
  14. Broken Byzan
    13,237
    466
    -What i do not understand is , a faulty turbo won't cause overfueling as the fueling is airflow driven. So no boost means less air, and therefore less fuel
  15. salsheikh
    24
    i think the overfuelling was due to the boost leak from the MAP sensor where the leak was found.
    white smoke coming from the turbo seaping oil
  16. Prawn
    11,667
    3,669
    That's all I ever get anyway! haha
  17. salsheikh
    24
    i was getting about 300-320 before...when i first got the car.
