Help On Windows Steaming Up
PhilW Nov 28, 2011
  1. PhilW
    PhilW Member
    182
    Its driving me nuts now, I can't drive in it at all without the windows steaming up.
    Battery tray and grommets are clear, so its not coming from there, carpets seem dry to me but i know they're pretty thick and elevated slightly from the floor plan.
    Any ideas or places where i can check to see if theres water ingress?
    Its a 02 plate Pd130 Avant.
    Thanks. :)
  2. marktdisport
    marktdisport Active Member
    1,195
    15
    boot or rear lights
  3. kev1000
    kev1000 Member
    209
    Mine too
  4. LandSpeed
    LandSpeed Member
    229
    is there anything damp kept in the boot ie golf clubs ?
    there is a vent on the saloons (i know this doesnt count on your part philW) under the high level break light which goes directly into the boot and any moisture from the boot area may make your windows steam up.
  5. PhilW
    PhilW Member
    182
    Nothing damp kept in the car no.
    Ill check the boot and rear lights tomorrow to see of there's anything coming in there.
  6. quattrojames
    14,050
    575
    I'm guessing you don't have a sunroof?
  7. LandSpeed
    LandSpeed Member
    229
    i have in mine, you think this may be a cause due to drainage channels being blocked ?
  8. quattrojames
    14,050
    575
    It's a possibility, in the olden day when sunroofs were common it was usually the first place to look.
  9. wazz
    wazz Member
    89
    Cabin filter?
  10. simon.m
    simon.m Active Member
    2,747
    pollen filter i have had this on mine when i first got the car was doing this so chanded it lasted about 2 years and it started doing it again the other week so put a new one in and all is fine again. it will not stop it complitly but a good 80%
  11. PhilW
    PhilW Member
    182
    No sunroof on mine, and im sure i changed the pollen filter about 6 months ago when i bought it. I'll double check tho.
    Do these have the same problem as the Passat with the pollen filter seal breaking down causing water ingress?
    Thanks tho people. :)
  12. kite
    kite Member VCDS Map User
    677
    I have had a leak on mine from around the ECU box, remove the drivers side lower panel, look up with a torch while someone pours water over the screen.
  13. PhilW
    PhilW Member
    182
    I'll check there as well. lol.
    I think ive found some small issues, theres a chunk taken out of the high level brake light that wouild let in water im sure which im going to seal.
    Also my rear washer isnt working which comes out into the boot along with a rubber seal misplaced on the boot.
    I think it might not be one thing but a few small leaks adding up.
  14. LandSpeed
    LandSpeed Member
    229
    can you let us know how you get on with this philW as i have the same problem
  15. Mike B
    Mike B Well-Known Member
    1,101
    40
    If theres water in the boot on an Avant this would cause the condensation,My last Avant seemed to take in water around the light clusters cos they werent tight and someone had left the flaps which should direct rain outside the clusters tucked inside probably when bulb changing.My current Avant had a slight leak in the washer line where it had been pinched in the gaiter from the roof .The other sympton was the weak jet of water which was only obvious when looking at the power of the jet on another Avant
  16. PhilW
    PhilW Member
    182
    Bringing this back from the dead.
    Had the carpets up on the passenger side. Bone dry.
    Checked the HVAC flaps in operation, no issues.
    Pulled the HVAC pipe and checked, not blocked.
    Plenum drains not blocked.
    Next up is to check round the rear lights again and check the drivers side carpets to see if theres water coming in through the ECU seal.
    Anything else to check?
    And also clean the windows.
    Thanks.
  17. PhilW
    PhilW Member
    182
    Ok checked the plenums again, both blocked but not much water there, probably about a pint of water. How much before it gets into the car?
    Nothing in the boot or under the drivers side carpet.
    Im just thinking its the windows that need a bloody good cleaning.
