help on replacing rear discs
khalil Oct 10, 2008
  1. khalil
    khalil Member
    774
    hi can anyone help me on this, i need to change the rear discs, the guy who is going to change them for me said that i have to change the bearings aswell, he said when you change the rear discs on the a3 you have to change the bearings too, is that true? or is it just a simple disc change
  2. bluequattro
    bluequattro Member
    411
    hi m8, im pretty sure its just a disc swap
    cal
  3. khalil
    khalil Member
    774
    ye that what i thought too, but his pretty sure that the bearings needs doing when you change the discs, his going to take off the wheel to confirm for 100%
    have you changed your rear discs?
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    did the rear brakes on my old A3 and they are attached the same as the front brakes, Im guessing the 8P is the same setup so unless they are noisy or rough I wouldnt be changing them.
    why do you need the discs changed? judder? worn? Make sure that the slides and pistons on the calipers are all cleaned and smooth as they are more likely to stick a bit due to being used less than the front.
    Maybe he just looking to make more money off you. I'd be looking for another mechanic....LOL
  5. khalil
    khalil Member
    774
    well the rear discs have a grove in them so i will need new discs, i used him for many years, his also a close family friend so i do trust what he is saying, but his not 100 % sure about the bearring thing,he will know once he takes off the wheel, so i was just wondering if any of you guys have changed the rear discs, so i know for sure what is involed
  6. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
    i think he is getting mixed up because on some older cars the rear disc housed the wheel bearing just like the drum brake housing, if this is the case the the bearing may get damaged when being taken out to transfer into the new disc.
    nowadays the design is different the bearing is seperate to the disc, i recently changed the rear bearing on my GF's Golf and the bearing was seperate and also cost £70 as its a sealed unit and i would guess the A3 one is a similar if not the same design.
  7. RobinA3
    1,826
    46
    this'll help you.
    the rear bearing is a seperate part of the system, the brake disc bolts onto the hub which housing the wheel bearing.
    hope this helps.
  8. khalil
    khalil Member
    774
    oh cheers mate thanks ever so much for that, now thats all cleared up, top work mate
