help on logging blocks on 1.8T 96
billybravo Jan 18, 2007
  1. billybravo
    billybravo Active Member
    1,045
    hiya can anybody help me do a log on my car
    i need to log the following
    lamda
    air
    spark
    and adv+ timing
    can anybody tell me how i do a log and which blocks i need to log cheers
  2. billybravo
    1,045
    ok i found out which block to log for the maf 002 or 003
    still looking for which blocks i need for
    timing
    spark and o2
  3. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
    What's your ECU's VAG part Number?
    -Uwe-
  4. billybravo
    1,045
    unsure i will have alook tomorrow why do you need this?
  5. billybravo
    1,045
    the part number for the ecu is 8D0 907557 does this help
  6. Uwe@Ross-Tech
    130
  7. billybravo
    1,045
    will this label file be already installed in vagcom or will i need to do this myself
    from whats on the file is the same as what comes up on vag.
    im trying to take these reading so i can make a base map for a standalone ecu
  8. Uwe@Ross-Tech
    130
    Depends what version of VAG-COM you're using. If you have the current one (607.3) then it's already there.
    -Uwe-
  9. billybravo
    1,045
    cheers mate thanks for your help
