Help on garages prices
TOTE Apr 22, 2013
  1. TOTE
    TOTE Just Me
    105
    10
    Hi i have been quoted £205 to replace the alternator pulley,as its seized and making a horrible noise.
    I live in sw London,can anyone recommend me a reasonable priced garage in this area thanks.
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    the only one i know in london is russell automotive
  3. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    You sure it's the alternator pulley?
    To remove/replace the ribbed-belt is pretty easy, with a spanner and an old drill bit you can lock the tensioner back. The alternator pulley is held on with a big bolt. Seems a pretty easy job to DIY.
    When my aux/v/ribbed belt was screeching it was in fact a seized aircon compressor & aircon clutch/pulley which ended up costing me over £1500 at the Audi garage. :sorry: And is a common problem ...
    Assuming you have aircon / climate control ...
    If it's actually a seized aircon clutch the garage is replacing then they're getting on for £100-£150+ for an OE part.
    I'd make sure the garage has diagnosed it properly, it would seem expensive to replace the alternator pulley.
    You can test yourself ... does the aircon disengage when you press the econ button?
    If the screeching goes away when you press the econ button and comes back when you turn aircon back on I think it's the aircon compressor.
    If the aircon doesn't disengage when you set the econ mode, then it's your aircon compressor clutch. Maybe.
    Or if that all works as it should, I have no clue and you can ignore me. :icon_thumright:
    Liam
  4. thegoal007
    thegoal007 Another S3 owner....
    805
    26
    volks autos ?
    In Sutton, just about in London.
  5. <tuffty/>
    21,874
    4,201
    If it the clutch type pulley you would need a special tool (shockingly!) to remove it... the pullies are fairly cheap...
    ALTERNATOR FREEWHEEL CLUTCH PULLEY 904VG0200
    13 PIECE ALTERNATOR PULLEY TOOL KIT | eBay
  6. TOTE
    TOTE Just Me
    105
    10
    Hi thanks,i have tested and wen i turn on the air con on the climate control.(the temp on the lowest possible the noise goes away)only came back wen i switch off the air con.just noticed that wen turning the steering wheel it makes more noise,but if i accelerate above 1000 rpm it goes away,now i am confused.
  7. BENJAMIN
    BENJAMIN Active Member
    503
    93
    That does sound very much like an alternator pulley issue. It doesn't do it when you have the a/c on as you're putting extra load on the belt, or above 1000rpm as you're taking the inherent harsh diesel idle away. This issue only really becomes apparent on the Tdi as it makes the steering judder and 'chirp' if at idle speeds, because the 1.8t is a smoother engine it doesn't get affected with the issue even though the pulley does seize up just as commonly.
    Its easy to change, and can even be done without removing the alternator if you use the special tool. Another option would be for you to remove the alternator yourself and take it in to a local garage and ask them to fit the new pulley for you, they'd probably only charge you £20 or so.
  8. Sham101
    Sham101 Member
    286
    20
    i can suppley and fit you a genuine pulley for £80 but you will have to come to birmingham
  9. TOTE
    TOTE Just Me
    105
    10
    Thanks for this really good explanation Benjamin,
  10. TOTE
    TOTE Just Me
    105
    10
    Thank you Sham101 if it was a bit closer i would take your offer.
