Help on 19 inch wheels!!
Nelson_R32 Aug 2, 2007
  1. Nelson_R32
    Nelson_R32 Member
    305
    Will these will measurements fit an S3 S-line FWD?
    Wheels: 9Jx19 ET52
    Tyres: 255/35/R19 96Y
    Neil
  2. Rabbit222
    Rabbit222 Active Member
    708
    125
    43
    I may be wrong but the correct offset for a S3 would be ET50 with a width of 8J and the correct tyre size should definitely be 235/35/19s. With a wide tyre like the one you have suggested, you are sure to have rubbing issues....
  3. Rabbit222
    708
    125
    43
    Here's a helpful link too.......
    http://www.qstuning.com/mtmWheels.jsp
  4. mjepson
    mjepson Member
    175
    You can use 235 or 225 tyres, with a bit of strech on 9" wide rims...
    I use 215 on my 8" wide 19" rims...
  5. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,497
    575
    Like has been said you could have rubbing issues, the offset is OK but the tyre is a bit too wide, which would also give you the wrong rolling radius and your speedo would read too slow
