Help.. not getting power through the 'constant' feed for the stereo
Splatt Feb 8, 2013
  1. Splatt
    Splatt New Member
    9
    Hiya,
    trying to install a new head unit in my A4 (2005 B7 - Symphony II), all is well apart from the voltage coming from the 'constant' feed, it seems to be between 4-6volts instead of 12V - and the unit won't work without 12v from both the ignition and constant...
    My Symphony was working fine, memory ok etc..
    Thought it may be the fuse... but can't see from the manual which one it would be and don't want to take them all out...
    Any help really appreciated..
    cheers
    Paul
  2. s8craig
    1,747
    53
    Symphony II only has a constant feed where are you getting the switched feed from?
    It uses canbus to power up.
  3. Splatt
    Splatt New Member
    9
    Hiya,
    There is a switched feed on the black connector - i.e. the + in the top right - the constant is the K....
    does that make sense?
    I have tested the + it is only powered when the ignition is on
    cheers
  4. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,698
    642
    The K is the dignostic wire for the symphony radio, the + is the main live feed it should not be a switched live.
  5. Splatt
    Splatt New Member
    9
    I'll double check that sorry... where is the switched feed then?
  6. Splatt
    Splatt New Member
    9
    Doh.. you're right the + is constant... so do you know where there is a switched one? the stereo won't work without both..
  7. B5NUT
    3,698
    642
    Go to the fuse box, and fine a switched live.
  8. AndyMac
    9,832
    45
    Or wire both yellow and red feeds on the new HU to the constant live and switch the HU on/off manually
  9. Splatt
    Splatt New Member
    9
    Thanks for all the help,
    How easy is it to attach a wire to the fuse box (never done that before - but willing to give it a go) and does the fuse rating matter?
    according to the manual, the radio fuse is 20amp - so I suppose one that was the same would be ok?
    cheers
  10. Splatt
    Splatt New Member
    9
    Hiya, tried the wiring the two together... and it won't switch off :-(
  11. B5NUT
    3,698
    642
    You may also end up with a power drain on the battery (depending on the radio) Just find one of the wires which is switched and just tap into it. You don't need 20amp for the switched live, just try and find one that is not connect to an important device I.E Engine ECU, ABS etc.
  12. Splatt
    Splatt New Member
    9
    Ok.. suppose the Cigarette lighter would be an option then... I know which fuse that is.. looks like I have to take the fuse box out to get to the wires... is that correct?
    Looking at the diagram there is a switched wire in the 'line out' of the triple plug (bottom left) - could I use that?
    Geez never thought this would be soooo hard :)
  13. B5NUT
    3,698
    642
    That's a line out of a radio that you have removed, so that's not going to work. If the cig lighter is switched live then go for that.
  14. Splatt
    Splatt New Member
    9
    Bit dark now... will have a go in the morning...
    Thanks for your help..
  15. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    That looks like mine (2005 A3) - if it is, as mentioned above, there is no switched ign feed like on old traditional stereos. The set takes all power from the constant feed and it "senses" the ign on and off via Canbus (as S8Craig said). You need to connect to the 20 pin mini-iso - there should be one (again if the 2005 A4 is similar) - you need to plug that into the back of your head unit so it gets the canbus signals.
  16. AndyMac
    9,832
    45
    The cig lighter is permanent live IIRC
    What HU are you fitting?
    No HU will not switch off if you have a live on both 12v feeds - that would mean you would have to have the stereo on all the time you're in the car whether you want it on or not. It won't drain the battery, the switched live does not drain any current if the HU is turned off
  17. NHN
    29,300
    1,703
    You'll need a repair wire from audi to fit into a spare fuse point, I cant recall which fuse points are ignition switched on a B7, but on the 8P for example, fuses 1-11 are, but a simple meter on spare points will advise easily.
  18. Splatt
    Splatt New Member
    9
    Hi all,
    Thanks for all the help and advice, managed to find a point in the fuse box that was switched and tacked on a fuesed feed from there..
    All working now..
    cheers
    Paul
  19. NHN
    29,300
    1,703
    You tagged onto an existing fuse point that is being used by other systems?
