Help no sound from rnse
tony-b-3.2-v6 Jul 8, 2012
  1. tony-b-3.2-v6
    tony-b-3.2-v6 Member
    120
    Hope someone can help my rnse has just stopped putting out any sound it still showing cd,s playing and sat nav but no sound
    Thanks in advance
  2. max69vk
    max69vk Active Member
    862
    57
    Try tapping the volume button once (so it clicks), you may have put in into mute mode.
  3. tony-b-3.2-v6
    120
    Tried this but to no avail its also started playing up and not finding my local stations think its something to do with my fin any help would be appreciated anyone know the best place to take it i live in the bolton area dont want to go to audi
  4. cooktowers
    cooktowers New Member
    Hi I am having the same problem - started today. No sound at all
    did you manage to get this fixed?
    cheers
  5. Sidhu88
    Sidhu88 Active Member
    808
    76
    What systems do both of you have?
    If you have a rear amplified system and you have no sound whatsoever its mostly issues with the RNSe
    If you have full amplified (bose) then it could be either the amp or the RNSe
  6. OCD-A3
    OCD-A3 Member
    118
    ^ Second this, check the fuse for your amp.
  7. hades-
    9,482
    646
    or take the main fuse out and leave it 12 hour
    this will reset the unit
    if it dont work then no idea
    TONY i dont think your fin will stop the sound
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    if it turns out to be your rns i have one i can do you a good deal on (MK1 SDS unit)
  9. NHN
    29,577
    1,779
    Do a reset by either removing radio & unplugging quadlock or press radio & setup together for as long as needs (usually 30 seconds or so) until screen goes of, see if this helps, if not then ideally needs testing in another car before sending of.
    Obscure I know but remove the nav dvd aswell.
  10. cooktowers
    Thanks for all the responses.
    It is the Bose system I have - I have tried the reset option / checked the fuse etc. I will try taking the fuse out overnight - will also take the DVD out
    I phoned a couple of local audio garages - if it is the amp they are quoting between £300 - £500 to replace. Think I will attempt it myself!
    The unit itself if still working fine as is the navigation - just no sound...
    Hard job to do - anyone attempted it?
    cheers
  11. NHN
    29,577
    1,779
    AMP is plugnpray, so not to much trouble, just make sure you get the correct one, just little pita to get too, behind rear drivers quarter panel.
  12. Plastic_Badger
    Plastic_Badger New Member
    25
    Hi did you get this fixed?
    I have the same problem!!
  13. NHN
    29,577
    1,779
    Does it have Bose?
  14. Plastic_Badger
    25
    Yes, from looking at other threads, could be the amp by the sound of it (or lack of in this case!)
  15. tomos8304
    tomos8304 New Member
    Did u find out what was causing this issue I've got the same problem on my tt 3.2 it also has the Bose setup
  16. Plastic_Badger
    25
    PHP:
    It was the amp. I fitted a used replacement one I bought off eBay and worked fine after, wasn't cheap though at about £100.
  17. tomos8304
    Thanks for your reply I've just sent Audi customer services a email saying that I'm not happy & I want this resolved but I won't hold my breath , looks like I'll be forking out for a new amp.
  18. NHN
    29,577
    1,779
    On a car how old?
  19. tomos8304
    The car is a 2007 but that's not the issue really I should of contacted them when the window regulator went (another well know issue ) but I just forked out for it, it's about time Audi addressed these issues,it's just a big money pit for them . I know people slag Renault off but I had my Clio 172 for nearly 10years & it never missed a beat maybe Audi should take some advice from them & sort there prices out accordingly
  20. NHN
    29,577
    1,779
    7 year old car, with respect you cant really expect everything to work perfectly for years & years, appeal to them for goodwill, but 7 years down the line I just don't see them being that kind unless you can show a repeated same fault on that chassis for numerous others.
  21. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,006
    773
    Have to agree with NHN on this you have to expect some things to go wrong over the years, yes they can fail but I've got a couple of Bose amps from 2005 and they are still running fine. Also with the amps it's not really Audi's fault they buy them from Bose and Audi cannot test them for 7 years before they put them into production.
    NHN likes this.
  22. NHN
    29,577
    1,779
    Also factors could of contributed to the failure, heat, cold, dampness, all kinds of things, which may not have been the amp at fault but something connected shorted or had a surge, etc, these things all have to be seriously considered, it happens.
