help!! no boost :(
tony696 Oct 12, 2010
  1. tony696
    tony696 Member
    165
    helloo all
    im in need of abit of help please. my alternator went on my car today, so i went a got a new one put it on but before i put it on i was driving myt car to euro car parts and i had no boost at all,
    which at the time i thought it was down to alternator been deadaswell as battery so i put a new battery and alternator on car and no theres no boost, and a loud whistle started to come from turbo so ive check all pipes and cant find and leaks and on fault codes stored on ecu ?
    can any one help pleaseee
    car is a s3 2000 apy:(
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Charge pipe connections adrift is what i would be looking at
  3. tony696
    tony696 Member
    165
    i will check agen tomozz its idleing perfect but just no boost
    thanks mate
  4. tony696
    tony696 Member
    165
    checked all boost pipes and they are all on ....any help ?
  5. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    check for boost leaks,what is you location ? there is threads on doing so somewhere?
  6. s3dave
    10,110
    736
    Have you got an aftermarket DV? I had a baileys DV that stuck open giving your symptoms...
  7. tony696
    tony696 Member
    165
    i have got a ebay recirculating dump valve..... do u thinki could block the pipe on the turbo pipe and seeif that works .
    ive got a felling it could be the turbo :(
    im inbirmingham mate ..
  8. s3dave
    10,110
    736
    You say you can hear the turbo spooling?
    I would take the actuator pipe off, and drive carfully to see if that gives boost...
    Other than that you need it on vagcom or similar, to see what is going on...
  9. tony696
    tony696 Member
    165
    i think im going to try that tomorrow, ive got the trial vag com so can do a few checks, but i will let u know anythings go tomozz
  10. tony696
    tony696 Member
    165
    ive tried taking the pipe off actuator and still no boost i think the turbo is no good time for hybrid i think lol :)
  11. s3dave
    10,110
    736
    Take the tip off and see/feel if the turbo is free?
  12. tony696
    tony696 Member
    165
    took the tip of the turbvo today and the blades was hard to move but it did move,, i think the turbo as gone :(
