OllieH
Hi folks, as per the title, abit of help is needed. With respect to my previous post http://www.audi-sport.net/vb/showthread.php?92297-Help-Boost-problem!&highlight= with a slow spool problem, I took my car to AMD Technik in Thurrock as I needed to get my geometry checked, so thought I'd kill two birds with one stone. They hooked it up to a laptop and took it for a spin and come back saying they couldn't find anything wrong with it. Now I'm questioning myself as to whether there is something wrong or not. I'm pretty sure before my coilpack problem my car used to make full boost at 2.5k revs, but now it's at 3k+ revs. This problem is starting to do my head in
Anyway, got home and had an idea. Looking at the specs of a completely standard S3 http://www.carfolio.com/specifications/models/car/?car=95502 it says the standard car makes 207 ftlbs from 2200-5500 rpm. So logged group 120 on vagcom and produced the hp/ftlb graph below:
Now, looking at the above graph, I'm not making 207 ftlbs till about 2600 revs! (400 revs later than oem) I have a custom code stage 1 map on the car so obviously my peak torque is going to be higher, but I should still be making 207 at the same revs shouldn't I?? I also logged requested vs actual boost to produce the following graph:
As you can see I'm not making full boost till 3,500 revs, so I'm actually only getting a small window of power.
The help I need is for someone, preferably who has a stage 1 custom code map (but I suppose any will do) to log group 120 and 115 for me on your car so I can produce some graphs from your data and compare to mine. Also anyones contribution to this as to whether its all in my head or not would be great. I really need to get this sorted now as my car just feels so slow at the moment it makes me feel like I don't want it anymore.
Bryzan A4 suggested on my last thread that it could be the wastegate not sealing properly, causing the slow spool. Has anyone experienced this before?
Cheers in advance :icon_thumright:
