Help needed with vagcom !!
Bradderz_1988 Aug 1, 2011
  1. Bradderz_1988
    3,951
    235
    Right I plug the USB in and it automatically installs through windows to comm port 3, so I install vagcom plug it in the car and do a comm test all says it's ok. Then I read the engine ecu to make sure it's all working fine, it is because I get my mixture code that keeps flagging up. But then I go to register through the about and it keeps coming up that vagcom has stopped working and that windows is trying to find a solution. Then closes vagcom now when I go back into it and select engine ecu it says vagcom has stopped working. And won't work at all any suggestions ?? Oh and I've just reset my laptop to narrow it down as it was loaded with **** and it still does it !!!
    I need help !! Lol
  2. aragorn
    18,315
    808
    If using Vista or 7 try running it as administrator. (right click the shortcut and choose "run as administrator")
  3. Bradderz_1988
    3,951
    235
    I'm using vista home premium and I'm the only user on the laptop if that helps but I'll have ago at dinner. When I first tried installing the USB it asked me to insert the disc and created a rosstech USB hardware now it just comes up USB mass storage or port can't really remember.
  4. Bradderz_1988
    3,951
    235
    Cheers aragorn it worked do I have to do that everytime I use it now even though I've activated it ??
    And also how do I change the setting so that when I lock the car I get a sound from the battery back up sounder ??
  5. aragorn
    18,315
    808
    I cant remember, just give it a try and see what happens! If it crashes without administrator, then always use administrator in future!
    As for the beep, you need to open the central locking controller, look up the coding value, and add 1024, then use recode to program the new value in.
    So if the existing coding is 12345, then you'd change it to 13369.
  6. Bradderz_1988
    3,951
    235
    All these codes are confusing me on vagcom is there a manual/write up on how touse vagcom, so I can have a good read through so I can get my head round it and use it lol
  7. Bradderz_1988
    3,951
    235
    That code worked aragorn, I've sort of Sussed measuring blocks out Gunna have a go at logging it to read the MAF values etc to see why my boost pressure is only around peak of 8/9 psi and also where do I find the oil pressure reading so when I do the turbo I can charge the turbo with oil and see that oil pressure has reached the turbo ??
  8. aragorn
    18,315
    808
    Yeh it just takes a bit of getting used to.
    Oil pressure is inside the instrument controller.
    Measuring blocks group1 or 2 i think
    It says Oil Pr <min, then changes to Oil Pr OK once its reached 1.5bar.
  9. Bradderz_1988
    3,951
    235
    Cheers mate il sus it out in the end just need to have a play lol
