HELP NEEDED WITH MY TURBO !!!!
motfree Sep 12, 2010
  1. motfree
    motfree Member
    464
    HI THERE NEW TO THIS SITE BUT GIVING IT MY BEST :-D
    JUST BOUGHT AN S3 2000 AND I THINK IT NEEDS A NEW TURBO AS I CANT GET BOOST AT ALL AND THERE IS BLUE SMOKE COMING OUT EXHAUST ON IDLE .. AT THE MO TURBO SOUNDS LIKE A JET BUT CANT GO FASTER THAN 80MPH WITHOUT REALLY STRUGLING
    ANYWAYS WANT TO FIT A NEW TURBO BUT BEEN TOLD ITS A NIGHTMARE COULD ANYONE HELP AND GIVE ME ADVICE ON REMOVING AND FITTING A NEW TURBO ? BEEN TOLD BEST WAY IS REMOVE SUB FRAME AND STEERING RACK ??
    CHEERS
  2. Andrew@A.L.D
    3,879
    617
    First no need to shout and turn off the caps
    2nd no need to remove the sub frame or steering rack
    The turbo can be removed from above if your a adequate mechanic, the easiest way to do it is to remove the head as you will have more room to work
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Did you buy the car like that or did you blow the turbo? If you bought it like that, did you not notice before you bought it?
    You can get the turbo fully rebuilt by CR Turbos for just over the £400 mark. Welcome to CRTurbos
    If you don't know what you're doing then give it to a mechanic who knows how to do it. It's quite a job to get to it so don't attempt it!
  4. Andrew@A.L.D
    3,879
    617
  5. motfree
    motfree Member
    464
    No just happend :-( but got a good buy on it .. Found a k04 turbo for £280 on eBay as mine isn't even getting boost so presume it's gone completely !!
    Got my mate helping tomorrow to get this off so I can make sure on model of turbo as it has a fmic and is kicking out 280 bhp so kind of thinking not a standard turbo ? Tried to have a look but no chance of seeing until some bits moved !
    Cheers for help guys
  6. motfree
    motfree Member
    464
    And located merseyside ...
