help needed with my 2001 s3 ????
cabrio boy Aug 16, 2012
  1. cabrio boy
    cabrio boy Member
    42
    Finding this site so helpful :O) Well after fixing a few problems with my s3 i have a strange one with my boost, :O( One day drive my car it reads 5.9 on vag.com next day it will read 8 or 9 psi few times it has gone upto 17 psi its all over the place and day by day different , most of the time 5.9 any ideas ????? the car has full samcos an arp remap and an arp r1 bov , newspeed induction kit
  2. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    Get the car scanned if you can and see if it brings up any fault codes, also have a look in the engine bay and see if there are any split pipes at all.
  3. <tuffty/>
    21,879
    4,202
    Guessing you are dipping in and out of limp mode or you have a big leak somewhere...
    Check all pipes under the inlet manifold for splits... be aware they may not be obvious either so pull them about a bit or see if you can get a smoke test done... they work real well ;P
  4. cabrio boy
    cabrio boy Member
    42
    right after a random 1 o clock in the morning look with a torch found a pipe loose which conects to the underside of the back right boost hose sorted that but now another problem grrrrrrrrrrrrrrr
  5. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    could be the arp bov causing it to overboost
  6. morgan306
    morgan306 Member
    142
    That video is private apparently Tufty!
  7. cabrio boy
    cabrio boy Member
    42
    new post up about new problem :O)
  8. <tuffty/>
    21,879
    4,202
    Fixed :)
