HELP NEEDED - STRANGE PROBLEM. Alternator whine feedback from speakers from standard
oneniner May 20, 2013
  1. oneniner
    oneniner Member
    77
    Help and advise needed as its really annoying.
    Car is a 2010 Sportback Black Edition with Bose
    Have only had a little over a month.
    Retrofitted RNS-E - No Problems
    Followed by Bluetooth - No Problems.
    Over the weekend installed stealth sub and amp from AndyMac.
    Sounds Awesome but had alternator whine and rear left speaker didnt work. Perhaps rear left channel faulty. Went to breakers and tried exactly the same amp. Now both rear speakers dont work. I tried my original amp in another A3 and all the outputs are fine.
    Now I disconnected the new sub and amp. All speakers work fine now however I still have whine which wasnt there before the install. Its especially bad when I accelerate, use the brake pedal and when I use the indicators.
    Any ideas from anyone? Will be going to a mates and plugging VCDS to see if it brings up any errors.
    p.s The bose wiring was spliced into to get the feed for the new amp. Remote and RCA. The power wire is still in the car but disconnected as well as the earth wire.
    HELP NEEDED!
  2. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    This happens most often when there is a missing or disconnected ground (earth) wire. Usually in the input pins of an amplifier. Pay strict attention to make sure all earth connections are in place, particularly when they are grounding shielded cables. With this kind of problem, more ground connections the better, although you may have to play with them a bit to kill the whine. Also, keep the RCA (phono connector) cables well away from the power cables, don't tie them together in a wiring loom. Hope this helps. Good luck.
  3. oneniner
    oneniner Member
    77
    Thanks for the info. Will check the wires going into the Bose amp. I remember when I wiggled the connector there was feedback from the speakers. Cant see there be a missing earth wire as none of it has been tampered with.
    I do now have the VCDS report which I will upload tomorrow.
  4. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
