Help needed: someone who has ETKA please.
Lewbo Dec 4, 2010
  1. Lewbo
    Lewbo Well-Known Member
    1,279
    110
    As title says I need a part number for my dsg mechanism the gear unit, I found a unit and just wanted to check it was the same part numbers. I rang audi and they reckon they cant give part numbers out. (bulls**t). If someone is willing to check I will pm my reg or vin all help is really appreciated thanks
  2. mike foster
    3,967
    Sorry - I don't have enough to go on with just 'the gear unit'.
    Perhaps if you tell me the part number of the unit you have found then I will check for you
  3. Lewbo
    1,279
    110
    the part number i have is 1k2 713 025 m think its from a golf just wanted to check its the same part number so i can buy and fit as its cheap thanks
  4. mike foster
    3,967
    Have looked in ETKA but can't find that part. What exactly is the part called ?
  5. Lewbo
    1,279
    110
    dont know what the part name is but its the actual gear mechanism under the gaitor and suround, that controls all the gears. if this helps thanks
  6. mike foster
    3,967
    Sorry mate - that number or description does not show in the bit I'm looking in ! 2007 golf or A3 dsg
  7. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 Team Akoya Audi S8 saloon Audi A8 quattro TDi
    15,164
    1,125
    I can't find the part via the part number either.
  8. mike foster
    3,967
    Nearest I can find is :- 1K1 713 025 L or 1K2 713 041 A (selector mechanism lhd or rhd )
  9. dunk
    dunk Member
    770
    a3 dsg selector is
    8p1 713 041c lhd 4 door
    8p2 713 041 c rhd 4 door
    8p1 713 041a lhd 2 door
    8p2 713 041a rhd 2 door
    not same parts as golf ones
  10. Lewbo
    1,279
    110
    could someone confirm what this part is with the part number
    1k2 713 025 AB
    thanks.
  11. mike foster
    3,967
    You can't just do a search on a part number without having a clue what make or model it has come from.
    ETKA is very good but unless you have the make, model and year it will not find what you are looking for !
  12. Lewbo
    1,279
    110
    sorry didnt realise its from a golf gti mk5.
  13. mike foster
    3,967
    What year 'cos I can't find it and what do you think it is ?
    Sorry , I'm doing my best but there isn't enough info !
  14. dunk
    dunk Member
    770
    i think this part number is wrong - or at least the letter after
    there is a 1k2 713 025 L from various seat models, and a N variant on jettas,
    there is a 1k1 713 025 AB (left hand drive version) which is from a 2006 onwards jetta (but presumably is also used in a golf?), the right hand driver verson is 1k2 713 025 AA
    these cars seem to have lots of different gearchanger mechanisms depending on which chassis number you have
