Help needed- S3 Xenons facelift into pre-facelift A3
NTT BIRCHY May 25, 2013
  1. NTT BIRCHY
    NTT BIRCHY Member
    31
    Hi guys has anyone put S3 Xenons facelift headlamps into my A3 1.8t 8L (1998).
    What needs to be done for them to fit and work???
    thanks in advance
    Birchy
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    You need to do a search mate.
    This has been covered a million times, but in short you need to trim a piece of metal from the wing which sits on the outside of the light cut out. You will also need to change the wiring to the lights for the different connections.
    It isn't easy and it isn't cheap. Personally I don't think it is worth it.
  3. NTT BIRCHY
    NTT BIRCHY Member
    31
    Hi thanks, it not the cutting the wing out part I'm asking its the loom. I have the lamps already given to me from a friend so its these connectors expensive and what other costs are involved??
    Birchy
  4. Gops
    3,198
    666
    It's the same as doing a facelift headlight conversion. All the xenon wires are internal to the headlamp, you only get the rectangle connector to which there are adapters on eBay for.
    NTT BIRCHY likes this.
  5. NTT BIRCHY
    NTT BIRCHY Member
    31
    Thanks bud, have you got a link for the convertors
    Birchy
  6. Gops
    3,198
    666
  7. NTT BIRCHY
    NTT BIRCHY Member
    31
  8. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    I picked up a set of facelift lights for £50 and thought they was really easy to fit I made my own adaptor looms
  9. NTT BIRCHY
    NTT BIRCHY Member
    31
    Cool thanks bud, the guy has left the connectors loom end on the headlamp so I can make my own 😉
  10. A3-Lee
    938
    226
    43
    The easiest way is strip the loom from the pre facelift lamp and connect it to the face lift plug
  11. NTT BIRCHY
    NTT BIRCHY Member
    31
    Cool thanks bud
  12. NTT BIRCHY
    NTT BIRCHY Member
    31
    All fitted today guys, thanks for your help guys your all top lads
    961890_622367954441212_338633268_n.jpg 975922_622367824441225_1062895697_n.jpg
    Now just need to adjust as they are far too high
