I had my cam belt and water pump replaced while on holiday in Yorkshire last weekend but when I called to collect the car, my mechanic mate asked me if I'd heard the rattle from under the rear of the car? I said I hadn't so he took me out for a drive and said that the noise sounded to him like a broken rear spring.
Sure enough, when I got the car home and felt around the N/S spring seating, I pulled out the top pigtail that had broken off, fallen inside and was bouncing around when I went over bumps. The strange thing was that I'd never heard the noise myself but my brother said that he could hear it while driving behind me with his windows open. The car sits normally on the road and behaves perfectly in all respects.
I'm now trying to source a replacement pair but I'm having trouble establishing whether or not the S-line needs special springs.
I've found Sachs Part No. 627445890 on line for £63.60 each but does anyone know if these will fit my car?
Also, I've been told that to replace the springs you need a special type of compressor with two long arms that pass through the coils as the standard type of compressor won't fit. Is this correct?
I'd appreciate advice and guidance with this.
