HELP NEEDED PLEASE !
cheech
hi can any 1 help me with these codes ive gotten of my a4 q ?
heres vag com log
Wednesday,21,March,2007,16:20:48
VAG-COM Version: Release 607.3-UD
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN Number:
Address 01: Engine
Part No: 8E0 907 401 N
Component: 2.5l V6 TDI G000SG 0003
Coding: 02005
Shop #: WSC 63351
Part No: 00005059
Component: 130 106KC318_1.V14390851385
AUZ6Z0C0125205
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04455
Shop #: WSC 00000
Address 08: Auto HVAC
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect.
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0606
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 3000
Coding: 0010602
Shop #: WSC 63351
Address 16: Steering wheel
Part No: 8E0 953 549 P
Component: Lenksáulenmodul 0611
Coding: 00021
Shop #: WSC 00000
1 Fault Found:
00886 - Turn Signal Switch (E2)
04-10 - Mechanical Malfunction - Intermittent
Address 17: Instruments
Part No: 8E0 920 950 J
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01400
Shop #: WSC 00483
AUZ6Z0C0125205
Address 45: Inter. Monitor
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv.
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1211
Coding: 06859
Shop #: WSC 63351
Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0003
Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0003
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0003
1 Fault Found:
00956 - Key 2
35-10 - - - Intermittent
Address 56: Radio
Part No: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 01201
Shop #: WSC 63351
No fault code found
i know about switch fault ( main beam on constant )
its 09 + 46 i need help with
many thx
Cheech
I think the 09 module is simply pointing you at the intermittent fault in 16.
As far as the 46 "Key" fault, that's more an advisory thing and can occur if you simply haven't used the remote fob on key 2 in a long time. Double check that both remotes work, if so, clear the fault and don't worry about it.
-Uwe-
what ive done is retro fitted cruise ! ( which is currently not working ?)
i dont think ive coded new stearing wheel module correctly ?
i say this as when i ran Vag-com last week i saved report and now the new module is showing a different code ie last wk was 00001
now 00021 ?
do you think this may be the prob ?
CAN YOU HELP WITH THE CODING AS NOT 100% ive got it right ?
can you help with poss logins for new stearing module ?
thx again
Cheech
