Help Needed! My ABS light has come on
GforceA4 May 13, 2010
  1. GforceA4
    GforceA4 Member
    111
    Hello all
    My ABS light keeps coming on intermittedly on my 1.8 TQS, took it to my mates garage to see if he could fix it but no luck.
    My mate suggested it could be the ABS pump or one of the sensors, what do you think??
    Or any suggestions what it could be???
    Would appriciate help asap as people are coming to view my car to buy it this weekend.
    G
  2. aragorn
    18,485
    855
    Just repaired the ABS on mine, was a cracked rear reluctor.
    VAGCOM will tell you which corner is at fault.
  3. evilbow
    evilbow Member
    188
    Just replaced one of my corner abs sensors now abs judder when braking, do you have to vag-com it after replacing a sensor to reset it?
  4. aragorn
    18,485
    855
    abs kicking in probably meansthe signal is weak, ie a corroded reluctor, or the sensor isnt in far enough.
