Help Needed! How to replace a bulb in the upper rear brake light cluster?
Mak Jun 8, 2010
  1. Mak
    Mak Azure Blue S3
    49
    As title, i have a bulb out in the brake light thats at the top of the rear window, can i just replace the bulb or do i have to replace the whole light unit?
    Also anyone know to to remove it?
    Thanks in advance...
  2. 1animal1
    9,978
    pull the trim off the outer window and unscrew the light...... then you'll need some tiny bulbs....to be fair id replace them all as once they start going, you'll never stop taking it all apart....Halfrauds charge around £2 a bulb the robbing shits.....although i think theres somewhere on the tinternet where you can get em cheaper
  3. Mak
    Mak Azure Blue S3
    49
    Absolutely spot on... thank you, thats just the answer i was looking for.
    I love this forum, very helpful and fast accurate answers!
    Cheers...
  4. bhafc78
    bhafc78 Member
    35
    I found the Halfords replacement bulbs weren't exactly the same size - they were a little bigger and poorer quality. Ended up getting them from Audi and was only £12.00 to replace the whole lot. Part number N90051002.
  5. Madeley
    Madeley Member VCDS Map User
    125
    Got mine off eBay £7 for all 10, the buld code is on the holder.
