help needed asap!!!
leeds A3 1.8T Jul 17, 2011
  1. leeds A3 1.8T
    leeds A3 1.8T Member
    40
    hi, iv got a a3 1.8t agu and having some prob's, iv changed the coil packs, air flow meter, temp sens and the plugs and still no joy. the car sounds like its running on 3 cillinders and shakes a lot aswel for life of me i cant sort it. could it be a fuel prob or something like that? please help me guys as i need the use of the car every day :(
  2. 666markyboy
    666markyboy Well-Known Member
    1,236
    57
    Have you had it scanned for error codes ??? first place to start really
  3. leeds A3 1.8T
    40
    no not yet but been told it may not show any faults, thanks for the help, how much dose it cost to have it scanned?
  4. leeds A3 1.8T
    40
    could it be the n57?
  5. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Don't guess dude get it scanned, theres probably an asn member close to you that'll do it for a beer.
    If you changed all the coil packs and it's still missfiring it could be an injector fault. But there's no point in guessing
  6. leeds A3 1.8T
    40
    ok thanks mate :) will if there is, was thinking a fueling fault :\
  7. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    I would say get it scanned too, my engine shook alot idle, you can see it rocking back and fourth...
    Turned out to be the Air mass sensor, i just unplugged it, restarted the engine and it went back to normal. Can run like it for abit, but would recommend changing the air mass asap (if that is the problem)
  8. leeds A3 1.8T
    40
    have done that, my mate has the same car and we were swaping things all over the car and still no joy :( will have to get her on the vagcom i think
  9. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,296
    372
    ...sounds like you spent a fair amount of money before trying to identify the cause, Why?
    Get it scanned. Even if you pay for a scan it can't cost as much as coilpacks, plugs, maf & temp sensor.... surely?
  10. Dani_B19
    9,360
    399
    Leak, you checked all the vac/boost lines? Check all pcv and under the inlet manifold.
  11. leeds A3 1.8T
    40
    got a guy coming out today to put her on the computer but been reading lots about the prob and think it could be a sticky valve :( will keep you posted on the outcome..........thanks guys
  12. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Could also be a HT lead, worth considering.
  13. Alex C
    3,296
    372
    HT lead? .....coilpacks?
  14. leeds A3 1.8T
    40
    car just been on the computer and no faults found, but we found that theres no spark to no.1 :/
    put new coil packs on 2 days ago so im stuck again :(
  15. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Check the loom that goes to the coil packs, you will have to pull all the black tape off and inspect
  16. Dane
    4,086
    182
    +1
  17. badger5
    9,575
    2,038
    AGU... Ign TCS pack on airbox.. no sparkie when its died
    pretty sure its this
  18. s3dave
    10,110
    736
    Good shout forgot it was an AGU....
  19. dannyh
    dannyh Nogaro S3
    795
    13
    Sounds like this is the Spark plug apmlifier to me mate, buy a new one and swap it over or try your mates. It will cause a missfire and it is fastened to the back of your airbox
  20. leeds A3 1.8T
    40
    cheers badger5 that was the fault!!!!!!!
    thanks to all who tried to help :) shes running sweet as nut now im back in love with the a3 now
  21. badger5
    9,575
    2,038
    glad it was the problem..
    good luck
  22. Dane
    4,086
    182
  23. badger5
    9,575
    2,038
    lucky (at times)
  24. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    i was gonna say but i was too late :( i had the same a few months back. Think it was sandip who said to try this first before anything else and it worked.
