help needed after replacing injector seals
epox Jun 16, 2013
  1. epox
    epox Active Member
    772
    74
    as above
    after replacing filters and seals to all injectors. the car is miss firing and smelling of unburnt fuel from the exhaust.
    wires to the injectors seem fine.
    i did not disconnect any of the fuel lines, just unboltet the fuel rail to get to the clips and injectors.
    any ideas
    thanks mark
  2. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,144
    1,978
    Have you put the seals in the right position Mark ?
  3. epox
    epox Active Member
    772
    74
    yes, just o rings and small plastic washer on end of injector.
  4. voorhees
    16,144
    1,978
    Sounds like when I changed mine and put the wrong seals to seal the joint on the injector
  5. epox
    epox Active Member
    772
    74
    thouth that to, seals came as a part of a kit, even put old seals back on! still getting a miss fire and loads white smoke from exhaust.
    thought this would be a simple job:sadlike:
  6. dusty
    dusty Active Member Team Nogaro Blue Audi S3
    267
    46
    Have you got the top and bottom o rings mixed up they look the Same but the part numbers are different
  7. epox
    epox Active Member
    772
    74
    did a quick test with injectors on fuel rail and not fitted into manifold, turned engin over, 1 injector spraying all the time!!!
    looks like the injector is fooked, swaped it over to other lead incase it was the wireing but got the same result.
    must have damaged it some how,
    cheers mark
  8. voorhees
    16,144
    1,978
    Visually you can see any problems,you been juggling them ?
  9. epox
    epox Active Member
    772
    74
    new injector all back to normal
    mark
  10. Scullies
    Scullies Well-Known Member
    1,543
    657
    thats some dangeroooos fault finding. :undwech:
    Glad to hear its all sorted now.
  11. epox
    epox Active Member
    772
    74
    ye not to be recommended, did have plenty of towel over the manifold:hubbahubba:
