Help needed!..3.2Q DSG Hesitant engine ~ 2k rpm
-Ju- Aug 26, 2009
  1. Coxylaad
    Coxylaad Member
    171
    if you have a torch it should be. the only thing in the way of it is the inlet pipe onto the TB.
    Definately not placebo effect. My car is notably smoother, and pulls a lot stronger low down the range.
  2. marmite
    marmite Counting the Tesco Club points
    1,101
    What did you replace the standard one with ? I assume taking to an Audi dealer is a waste of time as they will fit a new part that is identical ?
  3. Coxylaad
    Coxylaad Member
    171
    my little bracket had snapped, so i replaced it with a section of jumper cable as a temporary measure. might get the proper one in the future.
  4. edition
    edition Active Member
    1,426
    Does it look like it's been damaged, metal fatigue or corroded off?
  5. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,380
    214
    Is it still an improvement ??
  6. Coxylaad
    Coxylaad Member
    171
    yes paddy it is. the fuel economy is still rubbish, but you can audibly hear the difference in the engine now, its snarly again at at 2.5k rpm, and the pickup is much brisker.
    I havent checked the idle 2k rpm test, i will do that at dinner time
  7. Coxylaad
    Coxylaad Member
    171
    non of those edition, it was snapped.
  8. edition
    1,426
    Hi,
    Just had alook at mine and are we talking about a round say 5mm bar that is looped at each end, connecting the downpipe to the gearbox?
  9. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,414
    514
    Yeah, that's it Jonathon. Have ordered a replacement for mine as it's missing! about £8 with the required bolts etc.
    On a side note, just did the top mounts today :thumbsup:
  10. edition
    1,426
    Ah cool mines still there and looks pretty much new...
    Glad top mounts were ok. They easy enough to fit?
  11. Coxylaad
    Coxylaad Member
    171
    make sure its not snapped - mine was still there but when i moved the exhaust it turned out it was snapped, but it is held in the right position and looks fine.
  12. paddy
    5,380
    214
    Where is this little bracket ?
  13. -Ju-
    2,414
    514
    Yeah, about an hour start to finish.
  14. -Ju-
    2,414
    514
    It's below the throttle body down the back.
  15. paddy
    5,380
    214
    cheers Ju...will have to have a look tomorrow !
  16. motionlee
    motionlee Member
    98
    Wow over 2 nights i have been reading this, cant believe audi are not doing R+D on this.
    After reading this i too believe the fault was with the audi map, due to the r32 one, well done for you guys sticking with it, but since replacing this earth strap as it completely cured it, as i am not convinced for some reason this was at fault. The scope for me is the best way of diagnosing anything as its REALLY live data that is capeable of reading anything automotive, so when you are talking about pre cat lambda senors they are known as wideband/or broadband sensors, and they work completely differnetly to post cat which are zericona sensor's only really for monitoring the effeciency of the cat and very rarely fuel trim. The broadband sensor works at much faster rate and for anyone thinking that there's is at fault then get yourself booked in at a garage that as a scope (like the one i work at for the next week or so lol) please dont go throwing your money away at parts there are people at there that can help.
    My car is ok as i tested it when i brougt it but i suppose i cant expect it for long lol
    I am opening my own garage up in the next six weeks and would be willing to have a look at anyone's car if your problems carry on.
  17. paddy
    5,380
    214
    Hi Lee...welcome to the club ;) the one thing that makes me think this is not map is the fact that they all run ok at first start up...they get worse as they get warm. I am now looking at closed circuit breathing and crankcase pressure etc...the symtoms are what i would expect with an air leak...
    We will get there in the end :)
  18. bn9af
    bn9af New Member
    hey guys just read most of this thread and im enthralled! 2005 plate done 54000 miles, been doing it since about 45000, had spark plugs done at 48000 (slight improvement) and fuel filter done at 52000 (as part of a full service, negligable improvement).
    i find that it judders when cruising at 2k rpm, revs jump about when held trying to hold at 2k rpm, and at idle you can feel the engine vibrating/juddering. It varies from day to day how bad it is, but doesn't seem to get any better when the engine comes off choke. not had an engine warning lights come on.
    the only other symptom i can think of that i didnt see anyone else mention is that the valve in the tail pipe which closes at low throttle/engine speeds is no longer working. The way this valve works is that it meters the vacuum generated by the inlet manifold to determine how much power the engine is making. If the valve in the exhaust isnt working it stands to reason that there is a vacuum leak, making the exhaust valve think the car is always on full throttle.
    Since a few other people have mentioned this i would say its definitely worth changing, i've just not got round to finding out which vacuum pipe would need changing. I'm definitely going to have a poke around for that earthing strap on the exhaust since it looks to be a simple fix if its broken!!
  19. -Ju-
    2,414
    514
    Don't bother mate, I replaced the missing one on mine at the weekend and as I suspected there is no difference to the car either by seat of the pants judging or looking at the figures!
    Mine still runs well at the moment though, but when it does it the scenario that makes it feel worse is downhill on light throttle (i.e on cruise control)
  20. paddy
    5,380
    214
    I dont have that exhaust flap since i changed the back box. I cable tied the vacuum unit under the bumper. If i can find the take off point on the manifold i will blank it off and see.
  21. Coxylaad
    Coxylaad Member
    171
    paddy i would definately have that blanked off, cos that will definately be an air leak if the end of the hose is to open air
  22. bn9af
    bn9af New Member
    strap was fine, where abouts is the vacuum point for the tail pipe valve?
    only a thought but would it be possible for say 5 people with similar symptoms and 5 people without to lend cars to audi for a week or so to find out what is different between the good and bad cars? Obviously in exchange i would expect free repair!
  23. Coxylaad
    Coxylaad Member
    171
    that would be a good idea if they were remotely interested in this fault.
  24. edition
    1,426
    I can say 95% it's not the fact you have disconnected the exhaust flap pipe....... Mine does this hesitancy intermitantly and it has for some time....
    I have blanked the tail pipe valve pipe and this made no effect to the hesitancy........... Just made it slighly deeper sounding around town....
  25. motionlee
    motionlee Member
    98
    The one thing that makes me think its a map is that this is very common, the r32 suffered with it, and nearly everything remotely possible as been replaced by one of the other members. Therefore there is not alot left and what is left i cant see making a difference. Did anyone have a go at replacing the post cat lambda sensor's ?
  26. Coxylaad
    Coxylaad Member
    171
    nobody has replaced any lambdas yet as far as I know
  27. paddy
    5,380
    214
    Coxy...my exhaust vacuum pipe is not open..the vacuum lifter is still attached, its just not lifting anything. cheers anyway :)
    PS.... do the coil pack just pull off the plugs ?
  28. -Ju-
    2,414
    514
    Yes paddy they do, just bear in mind that they are slightly angled, 3 one way and 3 the other as per the cylinders.
    I checked all mine with a spare and they are OK, not saying yours are though judging by your fault codes lol!
  29. paddy
    5,380
    214
    I'm going to do the plugs Ju working on the assumption that the car was fine before its last long life service...
  30. bn9af
    bn9af New Member
    just for a bit of an experiment i disconnected the vacuum metering unit today (fitted inline between the inlet manifold and the vacuum canister, got some wiring loom coming off it) with the engine running and straight away got an engine management light on, but the car ran exactly the same. hopefully this means my issues with the exhaust valve are related to a vacuum leak, similar to others here, meaning a simple vacuum hose change may help. to my knowledge, inlet manifold vacuum should play a big part in how an ecu runs a car on idle. im going to try a few more things with this vacuum unit tomorrow in an attempt to see whats what.
    reconnected the loom and drove about 15 miles in 4 journeys and light switched itself off.
    i'm tempted to do the same with knock sensors, lambda sensors etc, as the ecu SHOULD revert to a master setting when the sensor is disconnected. if the sensor that is remove is playing up, the master setting the ecu reverts to should make the engine run better.
    also, further to other's comments, i have noticed a small exhaust leak near the flexi section. next service (due in about 4000 miles) i will be finding this leak, removing the manifold and welding up the hole. i'm in no position to spend over £1000 on an exhaust!
  31. edition
    1,426
    Does anybody know wether the mk4 or mk5 R32 downpipe is the same?? Seem to be lots of crashed ones being broken atm......
  32. -Ju-
    2,414
    514
    Had a look on Etka Jonathon and they do look different.
    On another note, I've been looking through some German forums (very difficult when you don't speak it lol!) and there is a software update for the 3.2 V6 that was released to address both rough idling AND jerky no-load operation! check it out HERE scroll down to post 2.
  33. paddy
    5,380
    214
    Anyone know where the temp sensor is ?? I'm told the first thing the ECU looks at on start up is the reading from the temp sensor and i wonder if thats my starting on 3 cyl fault..
    Cant get the link to work Ju ?
  34. -Ju-
    2,414
    514
    Works fine for me Paddy but here's the post:-
    My software is currently 7001
  35. paddy
    5,380
    214
    Thanks Ju...links working now so problem must have been my end. when i last took my car in with this problem they said they had checked for updates as i mentioned that the r32 had an update. My engine starts.. BDB
  36. paddy
    5,380
    214
    Where did you get your software number from ??
  37. -Ju-
    2,414
    514
    It's on vag com when you go into the engine module, after the Motronic ME7.1 etc.
    Just been down to Audi and as you say there are no updates showing on the system but I took a printout down and the CD is available to order for £1.87 + vat.
    They are going to order it in and as long as I sign a disclaimer and pay for the time spent, they will try and do it next weekend.
    Does looks interesting though when you read through the thread as it mentions that it leans out the fueling helping to control lambda and knock control whilst giving better fuel consumption and smoother running
  38. paddy
    5,380
    214
    Good for you Ju....fingers crossed :)
  39. -Ju-
    2,414
    514
    There is also mention in another 115 page thread regarding chain lengthening that there is too much ignition built into the map causing uneven running on light throttle under 2k rpm, which in turn puts extra pressure on the chain.
    See post 2236 by Zoran HERE
    Exactly the same symptoms as I have/had, I'm thinking the mystery is now starting to unravel:yes:
  40. edition
    1,426
    Hi,
    mine does the exact same thing on occations (the noise he is talking about....)
    so what do we think for a solution???
    I think this is it!!
