HELP NEEDED - 2009 number plate LED's
t8ups Oct 7, 2011
  1. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,079
    768
    Hi All,
    as some of you know i supply LED bulbs, but there is nothing for the 2009+ A3 without having to use resistors.
    so i was wondering if anyone would be able to help me out with some ACTUAL readings of the current that the car gives when the plate lights are on, you would need a multi meter to help.
    i would need 2 readings from the 1 car,
    car turned on with plate lights on.
    and car off with side lights on.
    if i can get more than 1 person to do this then i can see that the cars are running the same and i can submit these readings to the factory and they can make me the bulb with the higher resistants so it dont through an error on your DIS, and you wont have to use the external resistor.
    if i can get 2 members having a go for me then there will be a free pair of the new numberplate LEDs in it for you...
    would like it ASAP so i can get the testers in before the end of next week and then if successful then get a batch in to supply members with the 2009+ cars that are wanting to do this mod.
    Trups
  2. Jameze
    Jameze James
    523
    85
    AFAIK I don't have a multimeter :sorry: but if I can source one from someone then I'll get back to you! I'll ask a few people who might have one I can borrow.
  3. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    I SO want some of these Trups!! Will definitely be ordering some from you when you crack it. :wub: xx
  4. t8ups
    2,079
    768
    Thanks guys, cant crack it unless i have some readings from a couple of members!
    they should hopefully be no more than £10 a set depending how much the factory charge me for the modifications in the resistants but i can do a good deal for all.
    just hope we can get some in the next few days so i can get them over to me to test in a car and then il get the batch in!
  5. slade777
    slade777 Member
    763
    Same as Paulie all the lights I've ordered so far from Trups have been top notch!!!
  6. JordanFostersSN
    JordanFostersSN New Member
  7. t8ups
    2,079
    768
    still no one yet :(
  8. slade777
    slade777 Member
    763
    If you don't get any luck I'm 40 miles away could maybe drive up one day so you can test on my car!!
  9. ryanstewart9
    ryanstewart9 Member
    494
    Trups,
    I have a mate with a 10-plate Sportback. If I can meet up with him I'll try to get some readings for you.
  10. t8ups
    2,079
    768
  11. t8ups
    2,079
    768
    That would be cool Lance, we will keep an eye to see what happens as i want this moving asap so you can all get the bulbs in ready for the darker nights.
  12. t8ups
    2,079
    768
    Ryan, that would be awesome if you could, like i said in the OP, if i can get two readings then there will be a free pair in it for you.
    i also posted the other bulbs and lamp back out today so keep an eye out in the post.
    Trups
  13. wesley
    wesley Giac Extreme+!! Lovin it
    350
    23
    I've not forgot about you mate, my mate at audi is gonna test one for you when he has on 09 plate to work on!
  14. wesley
    350
    23
    Says in the Ad that they will trip the warning light on 09 onwards!
    'Featuring built in resistors, making these a simple plug and play procedure
    Some 2009 and newer models will trip a bulb out error code'
  15. t8ups
    2,079
    768
    Thanks Wez.
    if there is anyone local to me i am happy to take the reading off your car if you will let me?
  16. grimp
    grimp Member
    142
    14
    i would very much like to help you out, ill see if i can get my hands on a multimeter :)
  17. Chappy
    Chappy Call me Dan! Audi A5
    471
    25
    My car is 58 plate, does this mean I also can't have LED plate lights?
  18. Paullie
    2,076
    288
    Not necessarily, Chappy as I believe 1animal1 has LED number plate lights that work perfectly in his facelift S3, which IIRC is an MY09 also. Get in touch with him and he might be able to tell you where he got them from. :wub: x
  19. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    Do you still need these readings bud?
    I might be able to get mine out this week. I can measure my 59plate and my 61plate (when it arrives)
  20. t8ups
    2,079
    768
    yes i still need some reading if you can get me them, i need the reading in Volts.
    Thank
    Trups
  21. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    606
    Just had led puddle lights ,led map lights,led footwell lights ,led interior lights ,led number plate all working perfectly ,, thanks to t8ups , robina3 and my best mate wesley for fitting everything fantasic job....
