help! mirrors not working
lgu00174 Jul 19, 2013
  1. lgu00174
    lgu00174 New Member
    22
    Hi
    My 2008 a4 wing mirrors are not working. I can't adjust them from the switch on the drivers door.
  2. NHN
    29,300
    1,702
    Which feature isn't working, the mirror glass 4 way movements, folding, heated etc, need more info.
    Check door rubber for broken wires.
  3. lgu00174
    lgu00174 New Member
    22
    It's the mirror glass 4 way movement that's not working. Both doors not working.
  4. NHN
    29,300
    1,702
    Does it have electric folding?
    Check door rubber 1st for any broken wires.
  5. lgu00174
    lgu00174 New Member
    22
    Not sure if they are folding mirrors but they aren't folding at the moment. Had a quick look at the door rubber loom. How do you expose the cables easily
  6. lgu00174
    lgu00174 New Member
    22
    Just checked. They are not folding mirrors but they are heated
  7. NHN
    29,300
    1,702
    Whereabouts are you located?
  8. lgu00174
    lgu00174 New Member
    22
    Im in Lanarkshire. I had a look at the wires inside the rubbers. All of the wires looked in tact. The purple and white one in the passenger side was a little kinked.
  9. NHN
    29,300
    1,702
    Maybe the switch has become faulty, it hasn't got wet at anytime has it?
  10. lgu00174
    lgu00174 New Member
    22
    Not sure. I only bought the car a couple of days ago. How could I test to see.
  11. NHN
    29,300
    1,702
    Private or dealer?
  12. lgu00174
    lgu00174 New Member
    22
    Private
  13. Soot1e
    Soot1e Member Audi S4
    146
    15
    Have you checked the fuses. Full list of fuses and locations in handbook.
  14. lgu00174
    lgu00174 New Member
    22
    Checked the fuses too. Couldn't find one for the mirrors
  15. Soot1e
    146
    15
    Front right door mirror fuse is located in Right Hand Side of boot behind trim panel. Centre block, fuse 9, number 1 being the closest to the boot and counting going toward the exterior of the car.
    Front left door mirror fuse is located in panel on LHS of dashboard, accessible with door open. Centre block, fuse 8, counting from top to bottom.
  16. lgu00174
    lgu00174 New Member
    22
    Just checked these fuses and they are ok. I've checked every fuse and they are ok.
  17. NHN
    29,300
    1,702
    Its going to need diagnosing with vcds 1st to see if the switch movements are being seen, but one little thing, I wonder if the switch connector has popped out, door card of job.
    Does the switch illuminate at night like all the others, if not then it could be this.
  18. lgu00174
    lgu00174 New Member
    22
    Problem solved. As suggested the mirror switch was not plugged in. Thanks everyone for your help.
