Help Meeeeeee Starting issues
Gazthesparky
Member
Glasgow
Hi all
Having problems with the car starting and hope that someone can give me some advice
the problems started the other week when i came back to the car after shopping and went to start it. it wouldn't start just the starter motor just turning over nothing else no lights
after a few goes it eventually started but lots of lights on the dash esp brakes ext. i turned the car off and it restarted and cleared the lights no problem
over a couple of days it was fine then all of a sudden it did it again.
i thought it might be the battery in the fob so changed that and its been fine.
been out to the car tonight and tried to start it and no joy.
i scanned the car, and vcds couldn't find the engine module and lots of errors came up saying unable to communicate with the engine.
when i eventually got the car to start i scanned it again and the engine module was found.
i am thinking that it is the ignition coil stoping the engine turning over
when the car starts its fine its just getting it started
no lights show on the dash.
so question is, do i phone audi in the morning and order a new ignition coil and swap it over or does it sound like me engine ecu is on its way out ?
next question is what size torque screwdriver do i need to take off the lower cowling of the strearing column ? as i don't own any thin torque screwdrivers that will go in the long narrow hole
all advice helpful because I'm taring my hair out with the car at the moment its cost me so much money the last couple of months with lots of problems.
cheers
gaz
How about battery trouble.Have you tried to jump it when it won't start.
Do diesels have ignition coils? I thought they were compression ignition only.
Hi sorry
I don't mean the ignition coil in the engine I mean the barrel that goes around the ignition key to read the imobaliser code from the key fob
I have read that the cables / key reader coil that goes around the key go faulty and I'm guessing that the imobiliser isn't being switched off when the key is put into the ignition to start the car and hence the car won't start .
It's had a brand new battery the other week and it's turning over, the starter motor is turning but the car doesn't start. Which is making me assume it's the imoberliser not de activating and allowing the fuel pump on ect.
What confuses/ worries me is that when I scan it with vcds it Carnt connect to the engine ecu but when I finally get the car started after 20 or so goes. The engine and car drive fine and vcds can connect to the engine ecu.
I'm guessing and hoping that the imoberliser is locking out the engine ecu and that's why vcds is unable to connect to the engine ecu until the engine is running.
If that isn't the case then it's looking like a faulty engine ecu which I seriousuly hope it's not that:-(
If it was immobiliser car would start for 2 seconds then cut out with flashing key symbol. Have you checked your glow plugs?
There is no point guessing and replacing parts constantly. Get car scanned with someone who is good with vcds or take
Car to a specialist...
Right ok then so at least I know it's not the immobiliser because the car will start. It's looking like a costly trip to the garage then.
Just clutching at straws here but does anyone know why vcds wouldn't find the engine ecu ? Is there anything to check for ? I just hate to think that is a simple fix and I never checked it.
I'll post a scan in a bit see if anyone can throw some light on the matter
I'm off on Monday so will arrange for it to go to the garage but just want to check any things I can first.
I Carnt believe that this is something else to go wrong in a long list of problems
Handbrake stuck on so while fixing that had new rear discs and pads due to them needing it soon
The roof motor seized and had to strip it down to fix the roof
The battery died so needed a new battery
Major fuel leak the fuel line had cracked so new line required
New tyre on the rear due to a screw in the side wall
Plus it's due it's MOT in a weeks time
And now this
Plus I had to re insure the car again and pay road tax all in a space of 2 months so I'm megger skint at the moment
So any advice/suggestions gratefully received
One very broke and depressed audi owner
There is a relay that supplies voltage to the ecu,don't really know where it is,on some cars its in the ecu box,but I would like someone else to confirm this one is.
Have you checked the new fuel line?, tiny air leak can allow air in and allow all the fuel to run back to the tank, so when you start it no fuel until you wind it back up again.
I dont know if theres some way you can run the in tank fuel pump before trying to start it, get pressure up then see how it starts, can be a real sod finding these sort of leaks
On wifes a4 3.0 theres a fuel pump fuse in the fuse board under right hand dash side panel, one of the mini ones iirc?
I'd the same problem on an 8l a3 mate and it was relay 109 under steering wheel that was for fuel pump. It wAs out about 1mm I cable tied it in and never happened again. Maybe check
Take under steering wheel cover off and check the relays there are all in. Google to see which one in b7 is for fuel.
Thanks for the heads up. i will check the relays under the steering wheel tonight making sure they are all in place.
i'm guessing that its not the fuel pump due to the engine ecu not showing up on VCDS. I'm now thinking that there is a faulty relay somewhere which supply's the ecu module power. So if anyone knows which relay switches the power to the engine module and where i could find it id be very grateful
if not i'm going to have to get my laptop out on my day off on Monday and try and work out which relay is which.
until then i'm back using public transport
heres a copy of the scan log
as you can see there is no engine module listed which is making me think that its not getting power and hence not showing when i scan the car
the second one is when i eventually get the car going and its there and all ok
any other suggestions or help will be gratefully received
missing controller scan
Mileage: 84850km/52723miles-------------------------------------------------------------------------------
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004405
Shop #: WSC 00672 785 00200
VCID: 2C5C73A58FD9477E17F-8079
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x0013
Hex Value: 0x8598
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00100
Shop #: WSC 00672
VCID: 6CDCB3A51C59877E57F-5140
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 21001
Shop #: WSC 00672
VCID: 3D7A4EE137A3DEF6B01-4B04
1 Fault Found:
02071 - Local Databus
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Part No SW: 8H0 959 655 G HW: 8H0 959 655 G
Component: Airbag 9.42 H01 1840
Revision: 92H01184 Serial number: 003CZ000AK60
Coding: 0071114
VCID: 3E7849ED69A5C5EEA9B-806B
Subsystem 1 - Serial number: 6332BRB403B33275F
Subsystem 2 - Serial number: 6342BRB403B330F1I
Subsystem 3 - Serial number: 63729RB403BE72EF6
Subsystem 4 - Serial number: 63829RB403BE7297.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 04011
Shop #: WSC 00672
VCID: 418232114B5BBA16D49-4B04
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8H0 920 951 D HW: 8H0 920 951 D
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0006411
Shop #: WSC 00847 210 86431
VCID: 2E5879ADBAC5356E39B-5140
1 Fault Found:
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006411
1 Fault Found:
004 - No Signal/Communication - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 M
Component: Komfortgerát T3B 5442
Coding: 07855
Shop #: WSC 00672
VCID: 3E7849ED3AA5C5EEA9B-4B04
Subsystem 1 - Part No: 8H2959802D
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8H2959801D
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0003
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0003
3 Faults Found:
01616 - Signal Wire to Interior Monitor
79-10 - Please Check Fault Codes - Intermittent
49-10 - No Communications - Intermittent
00956 - Key 2
35-10 - - - Intermittent
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8E0 035 186 AL HW: 8E0 035 186 AL
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H0813398
Coding: 0730331
VCID: 71E2A2D16B7B6A96649-5140
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005079615
Coding: 0001822
Shop #: WSC 06314 000 00000
VCID: 4688210D32759D2EE1B-5122
End ---------------------------------------------------------------------
scan 2 when the cars running
hassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
Address 01: Engine Labels: 03G-906-016-BPW.clb
Part No SW: 03G 906 016 KN HW: 03G 906 016 KN
Component: R4 2,0L EDC 000SG 9894
Revision: --H06--- Serial number:
Coding: 0000072
VCID: 79F29AF1300B22D6DC9-802C
Readiness: 0 0 0 0 0
Coding: 0004405
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x0013
Hex Value: 0x8598
Hex Value: 0x0001
Coding: 00100
Shop #: WSC 00672
VCID: 6CDCB3A51C59877E57F-515C
Coding: 21001
Shop #: WSC 00672
VCID: 3D7A4EE137A3DEF6B01-4B1C
1 Fault Found:
Coding: 0071114
Coding: 04011
Shop #: WSC 00672
VCID: 418232114B5BBA16D49-4B1C
Coding: 0006411
1 Fault Found:
Coding: 0006411
1 Fault Found:
Coding: 07855
Shop #: WSC 00672
3 Faults Found:
00956 - Key 2
Coding: 0730331
VCID: 71E2A2D16B7B6A96649-5122
Coding: 0001822
VCID: 4688210D32759D2EE1B-5140
Right thought I would just sum up this thread just for people who might have a similar problem in the future.
I found out that the main power relay was faulty. This relay switches on and provides power to the ECU. The relay is situated underneath the ecu in the engine compartment.
I found that when the car wouldn't start if you banged the ECU box it would then fire up.
Took me a while but I managed to get to the bottom of it and fix it myself :)
Reactions: mancdan, mr.raw, jdp1962 and 1 other person
