Help locating Air Mass/Flow metre
col85 May 2, 2008
  1. col85
    col85 New Member
    i believe to have a problem with the air mass metre
    loss of power, juddering etc
    anyone help me locate the part? apparantly if i unplug the car will run better for now?
    any help on the issue is appriciated
  2. Issac Hunt
    1,162
    Model year? Engine?
    It will be in the inlet tract between the air filter housing and the inlet manifold.
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    Searching ETKA for Air Mass returns two results:
    1) Air Volume Meter
    2) Sensor for air mass meter (MY06 onwards - Chassis number wauzzz8p6a000001)
    Not sure if this is what you are after.
  4. col85
    col85 New Member
    thanks for these
    i located the sensor all seemed fine, think im going to have to take it to a garage to have the error code read etc before changing anything
