Help in the USA! 2011 A3 = how to change the brightness of the LED DRL's?
pretarion Mar 11, 2011
  1. pretarion
    pretarion New Member
    Hello from the west.
    I just purchased a 2011 A3 and noticed that the LED DRL's dim when you turn on the headlights.
    There is talk on here about changing the coding to allow the LED's to be brighter or to stay the constant brightness once the lights are turned on.
    Can anyone help me out?
    Tim
  2. Smoothie
    Smoothie Active Member
    1,431
    Yea they dim with dipped lights, and signal left/right! Would you still see them clearly with the lights on though even if they were brighter?
  3. pretarion
    The main reason is when I want to just run the fogs and LED's, the LED's dim. And I want the full intensity when I am running the fogs.
  4. Harrelson
    Harrelson Member
    173
    running full brightness LED's will blind you in fog. its reduced for a reason
  5. Minstadave
    Minstadave Member
    560
    19
    Why would you want to run the fogs without sidelights/headlights?
  6. pretarion
    ok, thanks alot guys! It was just a simple question that I was asking. I will look elsewhere!
  7. mike foster
    3,967
    UK has a different set up and different laws !
    The only way to get your question answered is to find someone near to you with VCDS who can have a look at the alternatives or take it to a dealer and ask them the question.
  8. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,663
    116
    If you have access to VCDS take a look in the module 09-Cent Elec. Thats where all the settings for DRLs are held. I did see some settings about DRL Dimming somewhere.
